1965 Cutlass Sway Bar Question
Old Jun 17, 2013 | 11:56 AM
HonestDave's Avatar
I'm pulling apart a 65 Cutlass chassis. I've noticed the front sway bar looks pretty thick. On a lot of my old GM cars (late fifties, early sixties)I've found the 6 cyl cars came with no front sway bar. Just wondering if the 65 f-85 6 cyl cars were the same with Olds. Would the Cutlass front sway be desired for another type? Maybe Chevelles or other A-bodies came with no front stabilizer bar, or maybe a thinner one.
Trying to decide whether I should take it off or not. Anyone know about this intriguing possibility .
Old Jun 17, 2013 | 11:58 AM
stan 65 cutlass's Avatar
my car has none,it was an option, also have a rear swaybar on that thing?
Old Jun 17, 2013 | 12:39 PM
HonestDave's Avatar
Hi Stan,
No rear sway bar. I've got to buy one for the 442, as it's missing. Have you got a front one on your parts car for the Cutlass, or do you want me to save this one for you?
Is it like the old Chevs, where you have to actually change the lower control arms as well?
Old Jun 17, 2013 | 12:54 PM
i guess i do have a front one, found this pic of odd chalk marks i found on my car, yes the rears have need the boxed lower control arms to mount a sway bar, your 442 will have em if still original
Old Jun 17, 2013 | 02:48 PM
Run to Rund's Avatar
In 66, there were 3/4, 13/16, 7/8 and 15/16" front bars with the lightest being on Buick 6 cyl, and the heaviest on 4-4-2. I don't know if 65s had that much variety.
Old Jun 17, 2013 | 02:58 PM
HonestDave's Avatar
Thanks, good to know. Might measure this one and see what thickness.
Old Jun 17, 2013 | 04:17 PM
HonestDave's Avatar
Do we know for sure if a car could be ordered without a front sway bar, or would a six cyl have got at least the thinest one?
Old Oct 13, 2013 | 11:12 AM
Carlos Ochoa's Avatar
65 cutlass do I need the frame reinforce? ??? because frame looks weak
I have a good 65 cutlass that was a v6 but. Who ever had it put in a olds 455 motor so I just check the cars fram because I want to make a limited slep and I saw the frame looks very week is stright and good just looks lil week do I have to get it reinforced? And around how much would that cost?
Old Oct 13, 2013 | 12:49 PM
HonestDave's Avatar
I wouldn't think the frame would be any different on a V6 car than any other 65 Cutlass, but I could be wrong. I've heard the radiator supports are different, but I think the frames should be strong enough. If you're just adding a limited slip rear end I don't imagine it adds that much stress to the frame. The 455 might be a bit of a pickle, though. Perhaps one of the members who is more familiar with this issue will spot this thread and give you a more expert opinion.
Dead Reckon
Suspension & Handling
Dec 1, 2013 10:39 AM
HonestDave
Nov 5, 2013 02:37 PM
misercola
Sep 21, 2012 09:37 AM
my72vert
Jul 10, 2010 03:28 PM
65Delta88
Aug 5, 2008 10:19 AM
