Rear Sway Bar Question
Old Nov 4, 2013 | 08:21 PM
HonestDave's Avatar
I put the rear sway bar on my 65 442, and used body mount washers for shims. Does anybody know if this will make a significant difference and weaken the trailing arms?
Trying to decide if I need to splurge and buy the $15 shim package or if it's just wasting time and energy.
Old Nov 5, 2013 | 07:31 AM
Mike77's Avatar
I think a metal space the shape of a washer would be fine.
Nice to have another Vancouver guy on the site. Were you at?. Iam right at boundary road and Canada way.
Mike
Old Nov 5, 2013 | 07:48 AM
droptopron's Avatar
delete
I don't know if it will matter but I think the idea of the shim is to have contact all along the way between the sway bar & the trailing arm between the two bolts. I think just having washers would allow a little more flex. Again, who knows if it will make a difference.
Old Nov 5, 2013 | 08:10 AM
HonestDave's Avatar
Mike
In Richmond right on the runway (Burkeville).
Old Nov 5, 2013 | 08:25 AM
The only purpose of the shims is to prevent distorting the LCAs when there is a gap. Washers do exactly the same thing as the factory shims. The only reason the factory used a large shim is because one part is easier to install on the assembly line than a stack of washers.
Old Nov 5, 2013 | 09:27 AM
HonestDave's Avatar
Joe, that's what I love to hear !!
Old Nov 5, 2013 | 12:35 PM
62 Cutlass Convert's Avatar
I may have missed it but do have LCAs that are boxed with an insert? The insert welds to the bottom and has a portion the goes up inside at the bolt location to prevent the arm from collapsing under the pressure of the SB bolts. Really necessary for proper mounting of the bar to the LCA. Or you can get factory or factory style ones with the insert already welded. OPGI has both the inserts and already boxed arms.
Old Nov 5, 2013 | 12:52 PM
HonestDave's Avatar
Yes, I have the boxed trailing arms. I'm guessing the sway bar got lost or disappeared, and never got put back after the rearend was changed. Just a guess, mind you.
Old Nov 5, 2013 | 01:03 PM
oldsmobiledave's Avatar
stubby or long?
Dave - on your lower control arms are they "stubby" boxed or "long" boxed?. If they are stubby then they are likely original to your car since only the '65 442 used the short version.
email me if you want to see pics of the difference.
Dave
olds442Dave@hotmail.com
Old Nov 5, 2013 | 02:37 PM
HonestDave's Avatar
Dave
I'll post a few myself and e-mail you as well.
76olds
Feb 7, 2014 04:34 PM
Dead Reckon
Suspension & Handling
Dec 1, 2013 10:39 AM
HonestDave
Oct 13, 2013 12:49 PM
misercola
Sep 21, 2012 09:37 AM
my72vert
Jul 10, 2010 03:28 PM
