Need rear end bushings advice
Old Apr 21, 2012 | 12:59 PM
jankyrre's Avatar
Can anybody give me an advice on which bushings I should use in the rear suspension.I understand there are bushings made of different rubber qualities available on the market.
I have sandblasted and painted all the rear suspension parts and the plan was to replace the bushings while disassembled.
Old Apr 21, 2012 | 02:30 PM
You have three options, stock rubber, polyurethane, and del-a-lum. The poly bushings are significantly stiffer than stock for improved handling at the expense of ride comfort. The del-a-lum bushings made by Global West are solid aluminum bushings with a thin delrin sleeve for a bearing. These are MUCH stiffer than stock. Both the poly and del-a-lum will require periodic greasing to avoid squeaks.
Also, note that on the triangulated four-bar rear suspension used on Cutlii and Olds full size cars, the upper arms twist somewhat with suspension motion. The stock rubber bushings are compliant enough to absorb this twisting motion, but the poly and del-a-lum are not. The result is binding in the rear suspension. You can solve this by either using stock rubber in the front of the upper rear arms or getting the aftermarket metal bushings with spherical bearings in them for that location.
Old Apr 21, 2012 | 04:35 PM
jankyrre's Avatar
I think I will go for the original rubber ones.
Fusicks and Supercar unlimited are selling them for about 20 dollars piece.Are these ok?
Then there are Moog,Prothane,Napa.Any experience with these brands?
Old Apr 21, 2012 | 04:59 PM
Moog and NAPA are reliable brands - the odds are that Fusick is selling the equivalent of those for a higher price.
If you are going for regular rubber bushings, there is no need to get anything "fancy" - just regular old auto parts store bushings are all these are, and you won't do any better by paying more.
Old Apr 21, 2012 | 05:02 PM
Can't ever go wrong with Moog or TRW. Prothane sounds like aftermarket polyurethane, not rubber.
Old Apr 21, 2012 | 05:17 PM
Dave Siltman's Avatar
Listen to what the guys here are telling you------it is sound advice. You will probably end up repainting some items because the bushings need to be pressed in. You might here some "flat-rate" suggestions on installations, but do youself a favor and do it right the first time. One other suggestion, if you are using a rear sway bar and the car didn't originally have one, by the time you "box" the standard lower arms and re-bush them, try pricing new lower control arms that are compatable with the sway bar. They are usually not that expensive and will be ready to install.
Old Apr 22, 2012 | 08:21 PM
brownbomber77's Avatar
Check speedway motors. They have a set of boxed with poly bushings for $205. I just don't know if they come drilled with the holes for a swaybar. But either way, it's a pretty good price for arms with bushings
Old Apr 23, 2012 | 01:54 PM
jankyrre's Avatar
A question from a stupid Norwegian,When you say boxed lower arms,do you mean the one on a 442 that are closed on all four sides?
If so there probably is an open version also?
I strongly suspect the bushings on my car is the original ones.The upper ones looks ok,byt the lower ones are getting quite concentric,if you understand my saying.
Anyway the rubber in them probably have seen better days.
I would not be suprised if even the rear shock absorbers are the original ones.
Old Apr 23, 2012 | 03:42 PM
Majic Jack's Avatar
rearend bushings
Muscle Factory, eight rubber bushings for ninty two bucks, not bad, and by the way, Moog, TRW and the like today are pass through brands.
Old Apr 23, 2012 | 05:12 PM
Nasty455's Avatar
XCELERATIONRULES!
I'll be replacing mine shortly,and will be going with new rubber bushings.
If the factory stock ones lasted 40 years,I see no reason to go with the new stuff.
I tend to stick to factory engineering whenever possible.
Old Apr 23, 2012 | 05:40 PM
pcard's Avatar
70 Cutlass SX
The "boxed" lower control arms are those which have all four sides. Some cars had a lower control arm with only three sides. The control arms with three sides were not good for sway bars. If you want a sway bar you must have a lower control arm with four sides. If you do not want a sway bar then three sides on the lower control arm is OK.
Snolab
Drivetrain/Differentials
May 1, 2015 11:02 AM
ah7910
Oct 21, 2014 06:58 PM
350TurBRO
Sep 12, 2014 11:52 AM
1969cutlazz
Sep 12, 2011 11:15 PM
tiparosa
Feb 26, 2007 10:43 PM
