What rear sway bar is this??
Old September 3rd, 2009, 08:33 PM
Lady72nRob71's Avatar
I recently bought a used rear sway bar that was supposed to fit my 72 Cutlass.
I just happened to be bored, so I compared my lower control arms and shims to the sway bar. No fit.
On the arms and shims, the bolt-bolt spacing is 6". On the sway bar it is 5.5".
The width of the bar from the edge holes is about 38". From the inner holes, it is about 41.5".
The bar is 7/8" dia.
Are the control arms wrong or the sway bar??
I'm glad I did not paint the sway bar black yet; as it might make for a good clothes hanging rod in the laundry room - white would be preferred then....
Lady72nRob71 is offline
Old September 4th, 2009, 06:23 AM
Well, I can tell you that the bar is NOT a factory 64-72 A-body bar. The factory bars did not follow the contour of the axle housing the way that one does. They were just "V" shaped. Yours looks like a G-body bar.
joe_padavano is online now
Old September 4th, 2009, 10:39 AM
Thanks Joe, that is what I was thinking too.
I will crawl under the '86 when i get home to compare them...
Old October 16th, 2009, 02:04 PM
Rob,
Joe is right (as usual),
Here are a couple of pics of the sway bar for my 72 Cutlass. I'm adding the components that are needed for the FE2 suspension (including boxed control arms and control arm braces).
These pics are 1" swaybar. Looks quite a bit different than the one you bought. BTW I double checked the bolt pattern and it is 6".
IMG_1128.jpg?t=1255726966
IMG_1129.jpg?t=1255726994
Obviously, this is upside down, but you can see the difference with the pumpkin bend.
Allan R is offline
Old October 16th, 2009, 05:55 PM
That's what I need - perfect! My car requires an upsidedown one - yours needs a rightsideup one.
I PM-ed you my address - overnight it please.
Thanks!
Old October 16th, 2009, 06:32 PM
jensenracing77's Avatar
Thanks!
are you looking for one? i think i have one. i will look if you need one.
jensenracing77 is offline
Old October 17th, 2009, 06:48 AM
Yes I still need one.
I can get a new repro 1"er for 98 bucks shipped to my door.
If I can get a used one for less, I would sure consider it. No pretty NOS stuff though.
Let me know what you might have - THANKS!!
Old October 17th, 2009, 10:48 AM
Eightupman's Avatar
-Rob, if you want, I invite you to try and sell that sway bar over on www.oldspower.com There are a LOT of G body guys over there.
John
Eightupman is offline
hamm36
June 5th, 2009 07:37 PM
agtw31
March 19th, 2009 07:49 PM
Olds luvr
January 19th, 2009 06:35 AM
cola
March 15th, 2008 03:08 PM
Carleta
July 4th, 2006 11:44 AM
Quick Reply: What rear sway bar is this??
