What rear sway bar is this??
Old Sep 3, 2009 | 08:33 PM
Lady72nRob71's Avatar
I recently bought a used rear sway bar that was supposed to fit my 72 Cutlass.
I just happened to be bored, so I compared my lower control arms and shims to the sway bar. No fit.
On the arms and shims, the bolt-bolt spacing is 6". On the sway bar it is 5.5".
The width of the bar from the edge holes is about 38". From the inner holes, it is about 41.5".
The bar is 7/8" dia.
Are the control arms wrong or the sway bar??
I'm glad I did not paint the sway bar black yet; as it might make for a good clothes hanging rod in the laundry room - white would be preferred then....
Old Sep 4, 2009 | 06:23 AM
Well, I can tell you that the bar is NOT a factory 64-72 A-body bar. The factory bars did not follow the contour of the axle housing the way that one does. They were just "V" shaped. Yours looks like a G-body bar.
Old Sep 4, 2009 | 10:39 AM
Thanks Joe, that is what I was thinking too.
I will crawl under the '86 when i get home to compare them...
Old Oct 16, 2009 | 02:04 PM
Rob,
Joe is right (as usual),
Here are a couple of pics of the sway bar for my 72 Cutlass. I'm adding the components that are needed for the FE2 suspension (including boxed control arms and control arm braces).
These pics are 1" swaybar. Looks quite a bit different than the one you bought. BTW I double checked the bolt pattern and it is 6".
IMG_1128.jpg?t=1255726966
IMG_1129.jpg?t=1255726994
Obviously, this is upside down, but you can see the difference with the pumpkin bend.
Old Oct 16, 2009 | 05:55 PM
That's what I need - perfect! My car requires an upsidedown one - yours needs a rightsideup one.
I PM-ed you my address - overnight it please.
Thanks!
Old Oct 16, 2009 | 06:32 PM
jensenracing77's Avatar
Thanks!
are you looking for one? i think i have one. i will look if you need one.
Old Oct 17, 2009 | 06:48 AM
Yes I still need one.
I can get a new repro 1"er for 98 bucks shipped to my door.
If I can get a used one for less, I would sure consider it. No pretty NOS stuff though.
Let me know what you might have - THANKS!!
Old Oct 17, 2009 | 10:48 AM
OldsMotion's Avatar
OldsMotion
-Rob, if you want, I invite you to try and sell that sway bar over on www.oldspower.com There are a LOT of G body guys over there.
John
hamm36
Jun 5, 2009 07:37 PM
agtw31
Mar 19, 2009 07:49 PM
Olds luvr
Jan 19, 2009 06:35 AM
cola
Mar 15, 2008 03:08 PM
Carleta
Jul 4, 2006 11:44 AM
