1980 Cutlass Body Bushings
1. Do you give two flips about staying original?
2. If the answer is no, then go to Summit, et al, and get a polyurethane cushion kit. Advantage is they'll stiffen up the connection between frame and body. Disadvantage- potential squeaks, but i haven't ever personally heard that happening. Also a slightly stiffer ride, but not overly so as to want to go back. It's actually a good upgrade. Get the kit and the new bolts if they don't come with the kit. Make sure to ask.
3. If the answer is yes, you'll need to find out all the various part numbers and seek out the long discontinued GM rubber pieces.
Good luck.
Good luck.
