1980 Cutlass Body Bushings
Old Sep 6, 2020 | 12:35 PM
Harmon's Avatar
1980 Cutlass Supreme 2 door
Have the body off and am replacing the body bushings. Im not sure who do buy them from. It is my understanding this frame is considered an A body?
Old Sep 6, 2020 | 12:59 PM
danktx's Avatar
Yours is a G body.
Old Sep 6, 2020 | 04:04 PM
CRUZN 66's Avatar
Olds Fever
Originally Posted by danktx
Yours is a G body.
1980 is an A-Body designation... Actual G-Body did not start until 1982...,
Old Sep 6, 2020 | 04:21 PM
69HO43's Avatar
1. Do you give two flips about staying original?
2. If the answer is no, then go to Summit, et al, and get a polyurethane cushion kit. Advantage is they'll stiffen up the connection between frame and body. Disadvantage- potential squeaks, but i haven't ever personally heard that happening. Also a slightly stiffer ride, but not overly so as to want to go back. It's actually a good upgrade. Get the kit and the new bolts if they don't come with the kit. Make sure to ask.
3. If the answer is yes, you'll need to find out all the various part numbers and seek out the long discontinued GM rubber pieces.
Good luck.
oldscs
Jun 27, 2020 04:17 PM
Harmon
Nov 21, 2017 04:32 PM
Bennettre46
Feb 20, 2016 08:23 PM
steverw
Oct 22, 2014 06:56 PM
Tlo154
Oct 5, 2014 03:18 PM
