What bodycolor is this? (-68 Delmont 88)
Old Sep 30, 2008 | 03:48 AM
Vargen's Avatar
Whatīs the name of the color on my Delmont 88? Which code?
Really hope that someone here can help me out with this!
Some pics taken with different cameras and lights.
Old Sep 30, 2008 | 04:24 AM
That is such a SWEET ride. Unfortunately, I don't know what color it is. Is it the stock paint?
Old Sep 30, 2008 | 04:38 AM
Vargen's Avatar
Thanks!
Yes definitely stock paint, the car was totally stock when I bought it.
Some parts have been repainted though.
Quite rare, 455 + 3-speed manual column shift
The interior:
Old Sep 30, 2008 | 04:40 AM
Oldsguy's Avatar
Past Administrator
I like it too. But don't know the color code, sorry.
Old Sep 30, 2008 | 06:10 AM
rocketraider's Avatar
Oldsdruid
If it's original it is Dubonnet or some GM Divisions called it Plum. It's a fairly rare color esp combined with the matching interior and top boot.
Old Sep 30, 2008 | 06:30 AM
2blu442's Avatar
Color
I have a 1970 442 with a similar color and it's called Burgandy Mist. I'll have to check the firewall tag after work to get the code. I don't know if they used the same shade from 1968 into 1970 and A-body to full sized. John
Old Sep 30, 2008 | 06:56 AM
In 1968 it was called Burgundy. Paint code is N. My very first 442 (a 1968) was originally this color, though I repainted it blue.
Old Sep 30, 2008 | 07:57 AM
Bluevista's Avatar
Registered
That's right, Burgundy, paint code N. I just went to TCP Global and looked at the paint chip sheet.
http://tcpglobal.com/autocolorlibrary/
Dubonnet wasn't offered in '68 and was an exclusive Toronado color before that according to my book, but anythings possible. The only interior color in the burgundy/red shade is Garnet and should be trim code 15 for a Delmont convertible, trim code 2 for the black convertible top.
Allan
Old Sep 30, 2008 | 10:54 PM
Vargen's Avatar
Perfect, thank you very much guys!
What does "POLY." stand for? Metallic?
http://www.tcpglobal.com/aclchip.asp...obile-pg01.jpg
Old Oct 1, 2008 | 02:44 AM
Bluevista's Avatar
Registered
That's a good question. I wonder what it denotes too? I'm not sure if it means metallic paint or because it is an acrylic paint with polymers? There are polyester primers and fillers they call that now. The solid colors on the sheet don't say it so I would guess it means metallic in this case ? Mine is 1971 code 24 Nordic Blue Poly and it does have a very slight metallic.
Allan
Old Oct 1, 2008 | 03:48 AM
Vargen's Avatar
Allan
I know exactly what you mean by "very slight metallic"!
I bought this car from the US last fall, and had of course only seen the car in pictures. I was 100% sure it was a solid paint, even after I got the car delivered here in Sweden. But when I washed it this spring I noticed in the direct sunlight that it actually looked metallic, but very slight.
You can compare these pics:
The paint looks very much metallic on the last pic, but IRL itīs not that obvious at all.
The reason I wanted the paintcode, other than just curiosity, is that I have to repaint the left rear fender - as you can see:
Old Jun 1, 2015 | 07:03 AM
68.eric's Avatar
Rims
Hey, do you happen to know what the name of the rims you have on the delmont? I been searching for these but can't ever find them. If you do can you send me the dimensions of them?
alexho73
Ninety-Eight
Mar 25, 2006 06:31 AM
FinnOlds
Feb 12, 2006 06:49 PM
Stephen
Sep 14, 2004 09:43 PM
