vista lower control arm
Old September 18th, 2012 | 10:18 AM
rktolds's Avatar
Is there a difference between a 68 Cutlass lower control arm and a vista? Rockauto.com has two different part numbers for the lower ball joint. The vista's is K5073 for $75. K5103 is for Cutlass and is $23.
Old September 19th, 2012 | 09:50 PM
As usual, RockAuto's online catalog is just flat wrong. By the way, those part numbers are for BALL JOINTS, not control arms. K5103 is the correct part for a VC. If you check the other applications for K5073, you will see that they are all FULL SIZE cars, not A-bodies. The listing is incorrect.
Old September 19th, 2012 | 10:07 PM
Lady72nRob71's Avatar
And here I was thinking that the VC got a different BJ that was heavier duty or such. I will have to remember this when I get a VC...
Old September 21st, 2012 | 04:58 AM
rktolds's Avatar
Yes I was talking about ball joints. I found it odd that the parts store and rockauto had it wrong. That being said it'd suck to own one of those full size models and pay $75 for a ball jt from rockauto!!
Old September 22nd, 2012 | 02:58 AM
Yellowstatue's Avatar
They have such a thing called a 'note pad' that you jot things down so you don't forget later!!
Old September 22nd, 2012 | 07:29 AM
Will you remember where i put it years from now?
Old September 22nd, 2012 | 11:54 AM
That's because both are getting their data from the same wholesaler's catalog, where the source of the error is.
Old September 22nd, 2012 | 11:56 AM
By the way, if you check applications on RockAuto, you'll find that K5103 IS listed as correct for the same year Buick SportWagon, which is identical to the VC.
oldzy
December 19th, 2011 06:43 AM
rodsolds
January 2nd, 2011 09:00 PM
big_wheel1971
January 23rd, 2010 05:34 PM
J-(Chicago)
February 5th, 2009 05:05 PM
72CUTTY
August 22nd, 2008 08:30 AM
Quick Reply: vista lower control arm
