vista lower control arm
Old Sep 18, 2012 | 10:18 AM
rktolds's Avatar
Is there a difference between a 68 Cutlass lower control arm and a vista? Rockauto.com has two different part numbers for the lower ball joint. The vista's is K5073 for $75. K5103 is for Cutlass and is $23.
Old Sep 19, 2012 | 09:50 PM
As usual, RockAuto's online catalog is just flat wrong. By the way, those part numbers are for BALL JOINTS, not control arms. K5103 is the correct part for a VC. If you check the other applications for K5073, you will see that they are all FULL SIZE cars, not A-bodies. The listing is incorrect.
Old Sep 19, 2012 | 10:07 PM
Lady72nRob71's Avatar
And here I was thinking that the VC got a different BJ that was heavier duty or such. I will have to remember this when I get a VC...
Old Sep 21, 2012 | 04:58 AM
rktolds's Avatar
Yes I was talking about ball joints. I found it odd that the parts store and rockauto had it wrong. That being said it'd suck to own one of those full size models and pay $75 for a ball jt from rockauto!!
Old Sep 22, 2012 | 02:58 AM
Yellowstatue's Avatar
They have such a thing called a 'note pad' that you jot things down so you don't forget later!!
Old Sep 22, 2012 | 07:29 AM
Will you remember where i put it years from now?
Old Sep 22, 2012 | 11:54 AM
That's because both are getting their data from the same wholesaler's catalog, where the source of the error is.
Old Sep 22, 2012 | 11:56 AM
By the way, if you check applications on RockAuto, you'll find that K5103 IS listed as correct for the same year Buick SportWagon, which is identical to the VC.
oldzy
Dec 19, 2011 06:43 AM
rodsolds
Jan 2, 2011 09:00 PM
big_wheel1971
Jan 23, 2010 05:34 PM
J-(Chicago)
Feb 5, 2009 05:05 PM
72CUTTY
Aug 22, 2008 08:30 AM
