Trim and moulding stud repair
Old Dec 28, 2008 | 04:17 PM
Colorado Olds's Avatar
We were taking the trim and moulding off Josh's 66 F85 the other day in preparation for paint and I accidentally broke one stud off. Can these be repaired, or are we just out of luck? This particular piece is the OLDSMOBILE lettering block along the bottom edge of the trunk. Two studs and I broke one. If they cannot be fixed, or if there is no way to reattach the molding, I guess I will need to buy another - anyone have one?
Also there is a narrow trim piece above that one that goes the width of the trunk - it looks like it has some kind of clips in addtion to some studs. How do we take this piece off without breaking anything?
Thanks.
Old Dec 28, 2008 | 04:43 PM
Eric Anderson's Avatar
If you don't wnt to buy a new emblem you could use some trim tape or trim adhesive to hold it on. Not sure about the clips on a 66 normally the trim will slide sideways to disengage the clips from the posts or you can use a trim tool to spring the clip.
Old Dec 28, 2008 | 10:09 PM
bigoldscruiser's Avatar
2 '66 98's
If you have access to the inside of the trim stud hole, drill a small hole in the trim where the stud broke off and insert a small screw from the inside.
EightballZ
Mar 24, 2014 05:03 PM
brownbomber77
May 31, 2013 04:20 AM
kbeler
Mar 28, 2013 08:30 PM
RPMRestoAndCustom
Apr 10, 2012 12:40 PM
arnoldjr
Sep 7, 2011 05:39 PM
