tightening body mounts
Not sure how the 68 compares with the 66, but here is a possible reference point if the exact numbers for '68 cannot be found...
http://tocmp.com/manuals/Olds/1966/C...BodyMounts.pdf
Not sure how the bolts and mounts compare...
Quote:
"Torque body mount bolts to 35 ft. lbs. for 33 through 38 Series.
For 52 through 86 Series, torque bolts to 45 ft. lbs.
Figure 2-3 illustrates the use of shims at No. 3 and 4 body mount locations on 56, 58 and 84 Series convertibles. The shims are used to obtain correct door alignment, a maximum of two shims for each of the mount locations.
For installation of body mounts, refer to Figs. 2- 3 and 2- 4."
This translates to about 1/2 - 3/4 "Gorilla Tight" for those using that scale.
In the 72's manual, it quotes:
"Tighten body mounts to 40 ft/lbs for all series."
This is right in between the values given for '66 - how coincidental...
One size fits all - easy to remember when I do this fun task next year or so!
ROCKET VAPOR
June 20th, 2011 07:50 PM
oldzy
June 12th, 2011 09:24 PM
