Taking the body off for new mounts on 64 cutlass vert
Old Aug 6, 2011 | 06:24 PM
dartphil's Avatar
Can anyone here tell me where the body mounts are located and how you access them on a 64 cutlass convertible? I have been all under my car from front to back and only see one on each side of the gas tank and under the radiator suport. HELP??
Old Aug 6, 2011 | 06:32 PM
TK-65's Avatar
There are round holes in the bottom of the frame. They lead to the body mount bolts. They are pretty easy to see.
Old Aug 6, 2011 | 06:38 PM
dartphil's Avatar
My frame has no holes in it, beleive me i have been looking .
Old Aug 6, 2011 | 06:54 PM
gearheads78's Avatar
car guy
Look up at these circled areas
66cutlasstires264.jpg?t=1312681774
Old Aug 6, 2011 | 07:14 PM
dartphil's Avatar
I see your pic but my frame has no holes except the ones behind the rear axle as you have circled. Also my frame is alot wider along the center section as it looks like 2 frames side by side. If I knew how to post a pic I would take one and show what i have.
Old Aug 6, 2011 | 07:19 PM
car guy
email me them and I will post them same as my username at verizon dot net
Old Aug 6, 2011 | 07:39 PM
dartphil's Avatar
Ok thanks I will take them in the morning and send to you.
Old Aug 6, 2011 | 08:58 PM
TK-65's Avatar
It has to have access holes in it, unless someone welded them up. I cant see why someone would do that however. The round holes in the frame are where the mounts are located.
Old Aug 7, 2011 | 06:43 AM
dartphil's Avatar
Angry
Your right TK someone did weld new metal over them,I just took pics and sent to gearheads78. So more unexpexted work for me that the previous owner failed to mention. Why can't people be honest when selling a car?
Old Aug 7, 2011 | 07:13 AM
66ninetyeightls's Avatar
Land Yacht Captain
THats strange. Why would someone weld up the wholes in the frame?
Old Aug 7, 2011 | 08:50 AM
car guy
This is not good. Looks like your frame was rusty and sagging and they just welded iron over it.
Old Aug 7, 2011 | 09:07 AM
Land Yacht Captain
WOW thats one way to do it.
Looks like the only way this body is coming off the frame is to cut through the mounts with a sawsall and then get a new frame.
Old Aug 7, 2011 | 09:33 AM
TK-65's Avatar
Why didnt you look under it to see that it has a frankenstein frame under it? Verts are notorious for having rotted frames. That wouldve been the first place I looked.
Id abandon the body mount project and just leave the car alone. The frame is shot and theres no telling what else is wrong with it. Save your money and just enjoy it as is.
Old Aug 7, 2011 | 09:47 AM
Chesrown 67 OAI's Avatar
I always thought that convertible frames are boxed in like that from the factory? -- the 67 vert I had looked exactly like the pix posted above? Maybe mine was "hand box welded" too??
Old Aug 7, 2011 | 10:04 AM
heres pix of mine!!
Old Aug 7, 2011 | 10:05 AM
Because the boxed convertible frames are notorious for rust. This was someone's quick and dirty fix. You will need to re-cut the holes in the bottom of the frame where they were from the factory to access the bolts. Be aware that if the frame was that rusty, then the body mounting bolts are also rusting in the cage nuts. These nuts are blind so you will not be able to access them to spray penetrating oil on them. The nuts will break free from their mounting cages and spin when you try to remove the bolts. This will require you to cut holes in the floor pans from the top to hold the nuts and remove the body mounting bolts.
Old Aug 7, 2011 | 10:16 AM
car guy
Originally Posted by Chesrown 67 OAI
heres pix of mine!!
looks like yours had a similar "repair"
The rolling chassis I posted above is a 66 convertible frame.
Old Aug 7, 2011 | 04:34 PM
If your pix are of a 66 conv frame -- then it is totally different from the 67. The crossmember mounts are even completely different for a 67 conv frame from a non-convert frame. Thats why i showed you the pic of the crossmember area on mine??
Old Aug 7, 2011 | 04:49 PM
The only difference in crossmember mounts between a 66 and 67 convertible frame is that the 67 mounts have an added-on section to allow the crossmember to mount farther back for the TH400 that was first offered in 67 on the A-body. Note also that the HD frame option under the hardtop and sport coupe cars was simply the boxed convertible frame.
Old Aug 7, 2011 | 05:13 PM
442_Mustang's Avatar
Holy cow!!!V That's a frame repair, huh? Wow!
halfmoontrail
Mar 17, 2013 10:28 AM
Wyze
Aug 26, 2010 01:54 PM
Southern_Hospitality
Jul 28, 2009 08:03 PM
bigbrother
17
Jul 6, 2008 05:27 PM
silverriff
Mar 3, 2008 04:57 PM
