steering issues
Old Dec 19, 2008 | 10:34 PM
gumbyssfakee's Avatar
steering issues
I recently put some 2 inch drop spindles on my 71 cutlass and it has become kind of difficult to control through turns. When on a winding freeway and I'm turning with the lane sometimes the car feels as if it wants to dart completely in the direction of the turn I almost want to call it over responsive steering. Any ideas on why this may be. The rear is stock height, the suspension is stock except for the spindles and for tires i have 275-60-15 and 195-60-15.
Old Dec 20, 2008 | 05:56 AM
The obvious first question is, which dropped spindles did you use? Next, how was the car aligned?
The fundamental problem is that changing the location of the wheel centerline on the spindle also changes the scrub radius of the suspension, unless the lowering spindles were very carefully designed and took this into account. Different wheel offsets can further change the scrub radius. You can somewhat compensate for this by altering the alignment settings, but you need a shop that understands what they are doing.
Old Dec 20, 2008 | 09:05 AM
I used the ssbc drop spindles, but now that you mention it i haven't had an alignment done on the car since I've had it so that could very well be the problem.
thanks
spindles:
http://store.summitracing.com/partde...5&autoview=sku
Old Dec 20, 2008 | 07:45 PM
hsckris's Avatar
I'd recommend considering upgrading the steering box too.
http://www.popularhotrodding.com/tec...box/index.html
CPP should have a kit to work on the Cutlass too.
Old Dec 21, 2008 | 08:10 AM
I think the term you're looking for is "DOH"!
Old Dec 21, 2008 | 06:05 PM
yea exactly. I was to busy talking about how mean the car looks now. thanks for the help.
Xlhowie
Jul 5, 2014 06:53 PM
Torkis
Apr 26, 2014 02:49 AM
crazy2353
Suspension & Handling
Sep 18, 2013 08:29 PM
Jetstar 88
Jan 31, 2012 03:29 PM
EmilyAndTheJet
Aug 20, 2011 08:29 AM
