Steering box adjusting nut
if the input to output is loose meaning turning the steering wheel a bit doesn't give anything at the pitman arm, yes you can loosen the locknut and tighten the stud a little at a time until almost all the play is gone. Don't overdo it or you will cause excessive wear inside the box.
Joel
Suspension & Handling
March 28th, 2011 09:30 PM
