Steering box adjusting nut
Old Aug 16, 2010 | 11:14 AM
MJAKS462's Avatar
I have heard that you can tighten the steering by adjusting a nut on the gear box. Any help with this available ? Thanks
Old Aug 16, 2010 | 01:08 PM
Run to Rund's Avatar
if the input to output is loose meaning turning the steering wheel a bit doesn't give anything at the pitman arm, yes you can loosen the locknut and tighten the stud a little at a time until almost all the play is gone. Don't overdo it or you will cause excessive wear inside the box.
Old Aug 16, 2010 | 05:37 PM
henryk8398's Avatar
Hangin' out...
...and don't even bother if your ball joints/steering linkage are worn. You need to correct that first or you are overcompensating for wear in the steering box and everywhere else!
Old Aug 17, 2010 | 03:19 AM
MJAKS462's Avatar
Thanks guys !
Just a thought here, If you learn and remember one little thing every day just think what you will have learned in a year.
bob p
Jun 4, 2015 01:53 PM
kansjfr
Jan 17, 2015 12:54 AM
Joel
Suspension & Handling
Mar 28, 2011 09:30 PM
MDchanic
Nov 19, 2010 02:54 AM
lionelbob
Nov 6, 2009 03:53 AM
