Scoop on hood
Old Jan 26, 2015 | 06:09 AM
Oldsragger's Avatar
Scoop on hood
Does any know who is selling this type of scoops? maybe this is fiberglass hood, but i mean only the scoop, or if any have weld together something before?
Old Jan 26, 2015 | 06:24 AM
This company has both bolt-on and Bond-on hood scoops.
http://www.eharwood.com/
Old Jan 26, 2015 | 06:47 AM
That is called a cowl induction hood. They almost always come as part of a complete hood. I have seen fiberglass scoops only, but that was a while ago. Check with the usual fiberglass parts vendors. I can guarantee you won't find a complete cowl hood for a 1979 Olds full size.
Old Jan 26, 2015 | 07:13 AM
That should add at least 50hp to your 307.
Old Jan 26, 2015 | 08:04 AM
Oldsragger's Avatar
Thanks guys,i will check out the website. yeah i guess its not complete fiberglass hoods out there for my car.
Eric: yes i hope so, lol , no i wounder if the bbo will be to high, but i will see, when it will be installed,or make some mencurments to see if it will work well with clearence.
I made a tall aircleaner bolt in the carb just to see what space i have, i have space as maybe 6-7" from the airfilter top to about 5-10mm under the hood, i hope the bbo with aftermarket intake with carb and 2" tall airfilter, will go clear under. the best ting if it will go clear. well i can always use the orginale intake if nessesary..
easytobedead
Mar 25, 2013 03:05 AM
Delmont 88 PA
Dec 17, 2012 05:27 PM
68cutlassdriver
Body work
Feb 17, 2011 11:06 PM
nickd
Body work
Sep 28, 2009 01:12 PM
smcurro
Oct 27, 2007 05:26 PM
