Right Front Lower Ball Joint Won't Torque
Old Feb 18, 2018 | 04:58 PM
RandyS's Avatar
I installed all new ball joints in my 66 442 Project a while back, and today I was adjusting the front brake shoes when I noticed that there was some play in the front wheel. I didn't notice it when I first in stalled them. The car has only been driven on to a hauler and off and in to the garage. I removed the cotter pin and attempted to tighten the castle nut, but the ball joint shaft is just rotating and I cannot tighten the nut any further. I'm thinking that maybe the chineesium ball joints I purchased don't have the right taper for the holes? Suggestions?
Old Feb 18, 2018 | 05:10 PM
CRUZN 66's Avatar
Olds Fever
If the front suspension is off the ground, apply some pressure upward on the lower control arm using a floor jack or some type of hydraulic pump jack... This may help seat the ball joint a little tighter while you try to tighten the nut...
Old Feb 18, 2018 | 05:14 PM
Charlie Jones's Avatar
Phantom Phixer
Ashcan the Chinesium . and get a set of Moog joints from Rock Auto # K5103 .
http://www.rockauto.com/en/catalog/o...ll+joint,10070
Old Feb 18, 2018 | 09:16 PM
RandyS's Avatar
It was up on a floor jack under the shock mount when I was trying to tighten it. I think it's time for a better ball joint.
Old Feb 18, 2018 | 09:18 PM
RandyS's Avatar
Thanks, just ordered a couple!
dennis_30281
Feb 20, 2018 11:34 AM
brown7373
Sep 15, 2014 06:16 PM
defiant1
Oct 29, 2010 12:41 PM
73toro
Jun 12, 2010 09:09 PM
70vista
Nov 19, 2009 05:54 PM
