Removing tar built up on front inner fenders
Old Apr 9, 2015 | 01:07 PM
W-27's Avatar
My front inner fenders (68 442) have a lot of road tar built up under them and I am wondering if anyone as clean theirs and if so what is the best thing to use to clean them.
Old Apr 9, 2015 | 01:12 PM
Tedd Thompson's Avatar
Many of the old timers have used turpentine to remove tar, still works today....Tedd
Old Apr 9, 2015 | 01:53 PM
W-27's Avatar
I should have specified that they are black plastic and not steel.
Old Apr 9, 2015 | 02:39 PM
wd40, lots of it.
Old Apr 9, 2015 | 03:23 PM
don71's Avatar
same but different
Yea, a liberal application of solvent and a putty knife. Let it soak in for a bit and scrape away.
Its lots of elbow grease, and you will get dirty.
Solvent could be diesel fuel, carb cleaner wd40 what ever works for you. Brush in on and cover well.
A little application with a heat gun might be helpful on the large chunks. Just be careful .
Old Apr 9, 2015 | 03:59 PM
Octania's Avatar
I will suggest a plastic scraper in order to preserve the plastic fender liner.
Old Apr 9, 2015 | 04:44 PM
W-27's Avatar
Great point on the plastic scraper. The reason that I am doing it is because I will be replacing the upper arm rubber cover (at the moment I am forget the correct term) and I figured it's the best time to do it. Once I took the rear bumper and cleaned the back portion and the front with Citronella out of all liquids. It worked so well I couldn't believe it. It was like using chrome cleaner that smells better.
Old Apr 9, 2015 | 05:46 PM
Rocketowner's Avatar
Lowes has Black Jack tar and Asphalt remover in a 12.6 Oz. Spray bottle that works well and is environmentally safe.As has been mentioned,use a plastic scraper,so your plastic inner panels will not be all scratched up! Larry
Old Apr 9, 2015 | 05:51 PM
In the past I have used charcoal lighter fluid with very good results. It was all I had on hand at the time.
Old Apr 9, 2015 | 06:02 PM
Magna86's Avatar
Oven cleaner will help remove the tar as well. Plastic scrapper/plastic bristle brush/soft scotch brite pads
jensenracing77
Jan 25, 2014 06:55 AM
oldsmobiledave
Jul 3, 2013 07:42 PM
jensenracing77
Apr 19, 2013 02:22 PM
cobalt
Feb 8, 2013 06:05 PM
jensenracing77
Dec 2, 2011 09:33 PM
