Remove body from frame
Old October 31st, 2011, 11:32 AM
mhouston44's Avatar
I just recently pulled my engine to do some overhaul work on it. I have always had issues with surface rust on my frame. the underside of the car has been sprayed with the tar like substance to stop rust but that was some time ago. it has since started coming off and its a nightmare to crawl under the car with a wire brush and disk to remove the rust. What do I have to do to take the body off the frame? what kind of lift is required to get the shell off? where do i put the lifting apparatus to pick up the cab. do stiffeners need to be put on the car body to prevent it folding up. Is this something that would be so much of a hassle and pain in the neck that i would just be better off taking it to a body shop?
mhouston44 is offline
Old October 31st, 2011, 12:20 PM
Someone on here had a great thread showing how they did it with some structural lumber and a chain fall in a tree. I'm sure someone else here will remember who it was.
Not that complicated.
MDchanic is offline
Old October 31st, 2011, 01:05 PM
A lift is the easiest way, or you can jack up the body, and roll the chasis out.
The easiest way to get the undercoat off is to strip the interrior, and use some Berns-o-matic propane torches and a scraper!
oldcutlass is offline
Old October 31st, 2011, 01:10 PM
TK-65's Avatar
http://www.ultra-high-compression.com/page7.html
TK-65 is offline
Old October 31st, 2011, 08:03 PM
mhouston44's Avatar
Great info guys, thanks. That looks very doable in my garage which means money saved! What kind od media do you all suggest for blasting the frame. It's got the undercoating and a good bit of rust scale. I'll prob have it powder coated when its ready
sixty9olds
June 14th, 2011 06:43 PM
1969goatman
August 30th, 2010 07:44 PM
skip79
August 27th, 2010 09:06 AM
KRICHEN922
July 1st, 2010 09:17 AM
STRETCH1
Body work
February 17th, 2010 06:09 AM
Quick Reply: Remove body from frame
