rebushing the frame
Old Jul 28, 2011 | 09:43 AM
dartphil's Avatar
rebushing the frame
Can anyone here tell me how big a job it is to replace the body bushings on a 64 Cutlass Convertible? Is this something a pretty good shadetree mech can do at home with just floor jack and jack stands?
Old Jul 28, 2011 | 12:29 PM
The biggest problem is getting the bolts out. The nut plates are in blind holes and if the bolt is rusted, the nut plate will break loose and start spinning. At that point your only option is to cut a hole in the floor to replace the nut plate then weld the hole shut.
Old Jul 28, 2011 | 12:49 PM
Get the car up in the air as high as you can, a lift and a tower jack work great! An air impact and penetrating oil, is your best buddy. I've found if you loosen them all, and then start replacing, it makes it a bit easier! Do one side at a time, remove all the bolts, jack the body, and replace the mounts. Then restart the bolts. Repeat on the other side. You will have to jack the body off the frame to remove the mounts from between the frame and body.
Don't retighten any of them until you have them all in place.
It's not that bad! Good luck!
Old Jul 28, 2011 | 02:04 PM
dartphil's Avatar
Thumbs up
Thanks guys it sounds like something i can do
Old Jul 28, 2011 | 03:48 PM
gearheads78's Avatar
car guy
This!!! I had a 99% rust free car and one of mine still broke loose.
Old Jul 28, 2011 | 03:54 PM
If its going to break, it will do it whether he attempts to replace them or someone else! He might as well try it himself.
Old Jul 28, 2011 | 03:56 PM
car guy
Agreed...just making sure he knows what he is getting in to.
Old Jul 29, 2011 | 05:18 AM
dartphil's Avatar
I gotta do something so i can close my doors easier ,So thanks for preparing me for the worse, I'll try to keep my cool when I do this LOL.
Old Jul 29, 2011 | 06:08 AM
BTW, there are specific cusswords to use at specific times, however I will not get into that now!!! If you are my age, 2 advil before you start will help!
oldsmobilty
Sep 27, 2012 04:26 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
