Rear sway bar installation
Old Jul 27, 2019 | 03:26 PM
teamwieland's Avatar
My ‘68 442 did not have a rear sway bar when I got it. Just installed a new 7/8” bar from OPGI and noticed the ends don’t line up perfectly with the LCAs. Forward ends fit perfectly but there is about a 1/4” space between the LCA and bar at the rear hole on each side. I see I can get a shim set which would cover both holes (sway bar did not come with a set of shims). Can I shim just the rear holes with some washers or should I try to bend the ends of the bar to fit the LCAs better so I can use the correct shims?
Old Jul 27, 2019 | 06:13 PM
First things first. The control arms may not be compatible with your new sway bar. Are they boxed?
Old Jul 27, 2019 | 06:35 PM
Yes they are boxed. Hardware kit included spacers, which I assume is for non boxed LCAs.
Old Jul 27, 2019 | 07:32 PM
The factory used shims between the ends of the bar and the LCAs. Actually, I've usually seen the factory shims all on one end rather than split evenly. That was a lot faster on the assembly line.
Old Jul 27, 2019 | 07:35 PM
Thanks Joe. Still wondering if I can just shim the rear bolt(s) as the forward ends of the bar fit perfectly, or if I will need to bend the ends so they are exactly the same angle as the LCAs and shim as in your pics.
78Cutlass4Speed
Mar 14, 2019 03:03 PM
71OldscutlassS
57
Jan 26, 2019 06:37 PM
frozencaveman
Suspension & Handling
Nov 4, 2017 03:38 PM
1965cutlassragtop
Jan 24, 2013 04:17 PM
oldzy
Dec 4, 2010 01:06 PM
