Rear Control Arm Bushings - 65 442
Old May 17, 2019 | 04:08 AM
craig442's Avatar
Question on the two rear control arm (Uppers) bushings that are pressed into the rear axle ear bracket. The two I removed, which appeared to be original, had the bushing flange spaced about 1/4 inch from the face of the axle bracket.
Is this the correct position ? One would think the flange should sit flush to the bracket.
Old May 17, 2019 | 06:01 AM
One would be wrong.
The bushing wants to be centered in the ear on the housing. If you push it all the way to one side, the loads from the UCAs are asymmetric, causing twist in the bushing and bolt as viewed from the top. Also, the outer sleeve has a step, so you can't push it in any further.
Suspension & Handling
Oct 29, 2018 09:06 AM
dennis_30281
Jan 18, 2018 11:24 AM
Harmon
Drivetrain/Differentials
Jul 28, 2014 12:07 AM
bigwillystyle
Dec 21, 2009 10:05 AM
t bell
Oct 23, 2009 08:26 AM
