Question on Prep for Applying a Sticker?
Old May 7, 2009 | 03:34 PM
Doug69Cutlass's Avatar
Member
I bought a GM Mark of Excellence sticker to go in the door jamb. I know the surface has been waxed in the past. What is good to remove the wax before applying the sticker? I was thinking about using alcohol or mineral spirits. Would those do the trick?
Old May 7, 2009 | 04:05 PM
Bluevista's Avatar
Registered
They give you alcohol soaked pads to remove the wax before you stick on accessory things so I guess that would do it.
Old May 7, 2009 | 04:07 PM
jensenracing77's Avatar
i used alcohol and was good. i also used a heat gun and made the area warm to the touch before applying the sticker.
Old May 7, 2009 | 06:56 PM
Member
Thanks, I've got a bottle of alcohol and that sounds like a good way to go.
amoman82
Apr 9, 2017 07:18 PM
72notchback
Body work
17
Aug 24, 2014 02:41 PM
matviar
Sep 4, 2012 09:28 AM
nonhog
Sep 1, 2010 08:44 AM
oldsca
Jun 14, 2010 05:46 AM
