Plastic Fender Well Repair
Old Dec 27, 2012 | 09:39 PM
OLD SKL 69's Avatar
GM Enthusiast
Hi all. I am currently working on an 85 Riviera and I have a plastic fenderwell that is cracked. (Would be the same as the 79-85 Toronado) It is not a major crack and just want to prevent it from getting worse. Has anyone fixed this type of problem before and what did you use? Thanks in advance.
Old Dec 28, 2012 | 06:59 AM
RetroRanger's Avatar
72 Olds CS
If astetics is not an issue you can drill some holes on either side of the crack and "sew" it together with some zip ties. If it has to look good to use black zip ties lol
This works good for dirt bikes and sleds to keep plastics from ripping more, but if it needs to be pretty this probably isn't the best methed
Old Dec 28, 2012 | 07:25 AM
You can also repair it with some thin sheet metal and rivets or small screws. Just form a thin piece of sheet metal over it using it as a patch.
Old Dec 28, 2012 | 10:26 AM
ROCKET VAPOR's Avatar
Lance
Pick one
http://www.evercoat.com/productcategory.aspx?cat=6
Old Dec 28, 2012 | 11:18 AM
Lady72nRob71's Avatar
Get a 3/8" long staple from a staple gun and hold it with a pair of pliers at the head. Heat it with a torch until it is nice and hot, then push it into the plastic (one tip on either side of the break) and let the tips melt into the plastic. After it is through, push it quickly through with the pliers until the head is at the plastic surface. After it has cooled, either bend the two prongs over, or, if they are secure enough in the plastic, just cut them off.
Dab on some black paint and you're done.
Old Dec 28, 2012 | 08:35 PM
OLD SKL 69's Avatar
GM Enthusiast
Thanks guys. I appreciate the suggestions. Will try one of those methods.
Old Jun 20, 2013 | 08:08 PM
stirlingguy's Avatar
plastic inner fender repair
Hi ; I`m new to the site but I had a plastic welding business for 5 yrs. and you can weld it but requires a hot air gun and the correct type of plastic I think the plastic is HDPE . The best way to match is to trim a strip from the fender from a place that won`t be missed , clean the area then used heat ,try not to burn it . You`ll have to play with the heat and use some pressure , if you trim your starter end on a 45 or more it will stick faster at first . When it cools you can use a die grinder an smooth it off.
The Bug Man
Body work
Aug 15, 2013 12:53 PM
Nufo
Feb 15, 2013 10:30 PM
nonhog
Sep 19, 2011 01:28 PM
oldfarmall
Jan 7, 2011 11:08 AM
ChrisM
Aug 26, 2008 07:00 PM
