My chassis just tore like tissue
Old Jul 16, 2014 | 12:22 PM
  #81
Ces's Avatar
Ces
Originally Posted by pogo69
After seeing those last few pics I myself would feel relieved....it is a nice clean isolated break and not hidden rot that would make me freak out about all the frame seems
Very glad to hear that
Old Jul 16, 2014 | 12:53 PM
  #82
Let us know what your welder says. Good luck!
Old Jul 16, 2014 | 02:37 PM
  #83
Ces's Avatar
Ces
Here's a list of parts we ordered today.
What do you all think?
This is for front suspension & steering repair / refurb, & big block swap.
The inner tie rod ends were not in stock so we'll get those somewhere else...
The 455 motor mounts have not been ordered yet but I am aware that we need them.
Old Jul 16, 2014 | 02:49 PM
  #84
Ces's Avatar
Ces
Thank you! My welder said it's no problem and he'll knock it out early next week.
We got a head start on his to do list, today.
My other mechanic came out and removed everything nessecery to weld her up.
So she'll be sitting until then...
Old Jul 16, 2014 | 03:40 PM
  #85
70cutty's Avatar
Beer Connoisseur
Glad to hear everything worked out and it's getting fixed.
Old Jul 16, 2014 | 05:15 PM
  #86
Ces's Avatar
Ces
Right on!
Old Jul 16, 2014 | 05:23 PM
  #87
Gary M's Avatar
Great news! Nice parts list. Way to go!
Old Jul 16, 2014 | 05:26 PM
  #88
11971four4two's Avatar
MOTORHEAD
Originally Posted by Ces
Thanks, kook.
Super helpful.
It's 2am and AAA refused to tow me, after waiting an hour for them to show up.
Now, I'm here in a parking lot, hoping Hagerty will get me home.
i have been called worse
hahahehe
hope your repairs go well
KOOK
Old Jul 16, 2014 | 06:47 PM
  #89
Ces's Avatar
Ces
cool! thanks
hahahehe
KOOK
Lol...
Thanks, BOSH.
Old Jul 16, 2014 | 07:38 PM
  #90
Just got a look at those close-ups. I agree that they look great.
You can see from the one picture, as Joe said, that parts of the cracks are rusty.
Interestingly, it looks as though the rusty parts are discontinuous. In other words, it looks (to me, at least) as though one edge cracked, then the entire bracket flexed repeatedly, other cracks distant from the first crack opened up, and finally the metal between those points fatigued and gave way, causing the catastrophic failure.
You can also clearly see how the broken edges fit together like a jigsaw puzzle, allowing for only one position for reassembly (obviously, the possibility of portions of the attachment area bending before letting go needs to be considered, but I don't see much, if any of that in these pictures).
Glad to hear you're headed in the right direction!
Old Jul 16, 2014 | 07:57 PM
  #91
I see the MAW's have kicked in. It is a good time to replace the front parts since you already have one side apart. Glad it's working out and hopefully you'll be back in the saddle shortly. MAW check the brakes and front wheel bearings while your there also.
Old Jul 16, 2014 | 09:33 PM
  #92
Ces's Avatar
Ces
Wink
great news.
*exhale*
I'm thinking of showing some of your posts to the welder!
Any recommendation as to putting the failed metal that has moved,
back in to place? A knowledgeable neighbor, who has a perfect 68 convertible Cutlass, commented that there is no place to "push against, or hold the two parts near each other and be welded together."
The welder/mechanic who is fixing it, voiced a similar concern along the lines of, "How am I going to push the torn and failed metal back into place so I can weld it."
Someone mentioned a car jack. I said that to him and he said, maybe.
I don't doubt the guy doing the job, but if someone knows some good working and or correct technique, I'd like to know what it is.
How is it done properly or what are some of the correct ways to do it.
Thank you
Yes, it's might as well time. We did the brakes first week I owned the car in early june... Pads were new. Fluid was new. Topped it off and bled them and they were excellent. The bearings are a good idea, though they seem fine. Haha I don't need any more MAW'S today... Today was a bit brutal on certain parts of my wallet. Like the part where I keep my money.
ugh
but really, spirits are high as progress happens and knowing things are being done right!
Old Jul 17, 2014 | 12:14 AM
  #93
rustyroger's Avatar
'87 Delta 88 Royale
great news.
*exhale*
Thank you
Surely this is something a welder should deal with on a regular basis. I make no pretence to be a welder, but I would measure the other side, and maybe put a few tack welds on the repair section to hold everything in place, re-checking as the welding progresses. Take the time to get everything aligned perfectly before any welding takes place, be patient, and double check everything.
As the whole suspension is coming apart for new bushings etc one MAW could be closely checking the other side for stress cracks while it's all apart.
Roger.
Old Jul 17, 2014 | 06:49 AM
  #94
If the piece that broke off is not salvageable, he can fab a new bracket and weld into place using the old one or the one on the other side as a guide. He just needs to make sure that the metal thickness and where it attaches to the frame is the same so the vehicle stance nor alignment does not change.
Old Jul 17, 2014 | 06:57 AM
  #95
Professur's Avatar
Simple. I wouldn't. I'd cut away any stressed metal and weld in fresh. Then I'd line up the bracket and weld it clean onto the new plates.
Old Jul 17, 2014 | 11:18 AM
  #96
I would REALLY try to find a front frame section from a donor car and weld that in.
Old Jul 17, 2014 | 11:23 AM
  #97
Professur's Avatar
Naturally that would be optimal ... but unlikely
Old Jul 17, 2014 | 11:31 AM
  #98
Why? Nearly any 1968-72 A-body is a potential donor. The savings in welder labor will more than make up for the cost of the frame section, and the finished product will be infinitely better.
Old Jul 17, 2014 | 11:51 AM
  #99
Professur's Avatar
I wouldn't want to go cutting up one good frame to repair another good frame to start with ... so I'd be looking for a damaged frame with that section in good shape. That would seem to me to be a thin market. Savings in welding labour? I'm not seeing it. Take a piece of 14ga sheet, bend it to match in a press brake (1/4" radius would be my guess)... cut to fit and weld in. Should be under an hour's labour ... I think you'd spend a lot more time trying to track down that donor frame myself. And there'd be no lingering questions about the quality of the donor ... virgin steel has no history.
Old Jul 17, 2014 | 12:04 PM
  #100
pogo69's Avatar
morgan
Roger.
I agree with this and i am not a great welder but anyone that welds for a living will figure this out easily...the floor jack sounds good...some type of craddle wedged up to hold it at least to just get a few tack welds in place
Old Jul 17, 2014 | 12:09 PM
  #101
Oh yeah, nothin' to it...
That section of frame isn't flat, and I'm not even sure it's constant width. Can someone fab and weld a piece in an hour? Yeah, sure. I just wouldn't want that level of "workmanship" on my car. Oh, and then you have to remove the LCA bracket from the torn piece, clean it up, locate it properly, and weld it back on. Sorry, we'll have to agree to disagree. A clean butt weld to another frame section will be much easier in my opinion. And unless the O.P. has owned this car since new, there's no history on THIS frame either, other than it has cracked catastrophically.
Old Jul 17, 2014 | 12:22 PM
  #102
... the finished product will be infinitely better.
What scale and units are you using to measure this?
Old Jul 17, 2014 | 12:33 PM
  #103
pogo69's Avatar
morgan
i think its the 'debbie downer' scale for the poor guy with problems....but it would be the highest level fix for sure, but debatable
Old Jul 17, 2014 | 12:34 PM
  #104
70cutty's Avatar
Beer Connoisseur
Hey Ces, there is a 71 El Camino frame for sale on CL for $400, from Sac area. This would be a good donor, El camino was based on Chevelle platform from 64 to 77. I think this would be a better option.
http://sacramento.craigslist.org/pts/4562435070.html
Old Jul 17, 2014 | 12:37 PM
  #105
That would be the Bachmeiher Scale, though usually we abbreviate it.
Old Jul 17, 2014 | 12:39 PM
  #106
Professur's Avatar
I'll agree to disagree, but I'm not sure what it being flat or a constant width has to do with anything. As for history .. I'm talking about the patch from the donor ... it's going to be 40-50 years old, with how many micro fractures from enduring the same stresses that caused this existing one to fail.
Old Jul 17, 2014 | 01:56 PM
  #107
Ces's Avatar
Ces
I just heard back from Mike's Auto Body in Lafayette California. They said they are unwilling to take on the work because of the liability and because the bracket that is torn and mangled is a suspension point. They're of the opinion that the mangled bracket needs to be replaced. However they are unwilling to do so.
Seeing as my welder thinks that he's going to be repairing the existing bracket, it sounds like I should make him aware of this new information.
Old Jul 17, 2014 | 02:03 PM
  #108
I would let your welder decide the best way to repair it. It doesn't matter what anyone says who has not seen it in person. Not to cause an argument, but anyone who has not put an eyeball on the job at hand has no clue to what exactly needs to be done.
Old Jul 17, 2014 | 02:05 PM
  #109
70cutty's Avatar
Beer Connoisseur
Here is another option.
http://sacramento.craigslist.org/pts/4552887405.html
Old Jul 17, 2014 | 02:25 PM
  #110
Ces's Avatar
Ces
Thanks man. I've got my eye on that in case we need it!
Old Jul 17, 2014 | 02:28 PM
  #111
Ces's Avatar
Ces
Seems reasonable. I've been keeping that in mind.
While asking people for their opinion...
I'd much rather hear multiple ideas than few or none.
Ultimately, it's up to the person I've trusted to do the job.
If he has any questions, I can always ask him to read this thread.
That's why I appreciate all the feedback here.
CO really came through on this thread for me.
I'm well thankful
Old Jul 17, 2014 | 03:06 PM
  #112
I think those prices are high. Here's a couple examples:
www.rockauto.com
Upper Ball Joint
MOOG Part # K5108
$18.05
Lower Ball Joint
MOOG Part # K5103
$20.79
Those items alone are $36 cheaper than what's on your list.
Old Jul 17, 2014 | 05:01 PM
  #113
Ces's Avatar
Ces
www.rockauto.com
Upper Ball Joint
MOOG Part # K5108
$18.05
Lower Ball Joint
MOOG Part # K5103
$20.79
Yes thank you, I'm a aware that these parts can be had for cheaper.
I used OPGI for the convenience of ordering everything from one place at one time. I had one of my mechanics and the insurance appraiser here all at the same time and it was getting very complicated. When I asked, "what do you think?" I meant the quality of the parts and if I had missed anything...
By the way almost everything I ordered as far as suspension bushings is made by Moog. I'm thinking that I got some really good parts. Yes, I could've saved some money but I didn't have the time to shop around and I didn't have the time to order from multiple places... Unfortunately.
Old Jul 17, 2014 | 05:35 PM
  #114
68conv455's Avatar
Your car looks great. You could always sell it cheap to someone in the rust belt with a welder in their garage.
What do you know! I have a welder and live in the rust belt. It would look great next to my 68.
Old Jul 17, 2014 | 06:04 PM
  #115
Well, you shoulda said "what do you think of the quality" and not left it open ended.
The ball joint numbers showed up as made by Pro Forged. I have never heard of that company nor have I heard of anyone using them, so no idea as to the quality.
Well, you coulda done that at your local auto parts store. ANY auto parts store, for that matter. There's no need to use a resto house for this kind of stuff. And it's a lot easier to do warranty returns, exchanges, and such locally.
Old Jul 17, 2014 | 06:58 PM
  #116
Ces's Avatar
Ces
Cool, thanks.
Maybe I'll return it all and find it cheaper like you suggested.
OPGI murdered me on this order.
It was $911 with shipping ....
Not cool
Old Jul 17, 2014 | 06:59 PM
  #117
Ces's Avatar
Ces
Ok deal! Gimme $15,000 and it's yours.
Shipping not included
  #118
I used my car as a test mule for Proforged center link, tie rod ends, idler arm, pitman arm and aluminum adjustment sleeves. They are still on my car today and work flawlessly.
Old Jul 17, 2014 | 07:02 PM
  #119
Ces's Avatar
Ces
edited for relevance
Old Jul 17, 2014 | 07:04 PM
  #120
Ces's Avatar
Ces
AND! You're telling me what I should do?
Get serious
