Lady gets a Front End job!
Old April 5th, 2012 | 04:32 PM
  #121
Troys Toy 70's Avatar
Once Olds Always Olds
Originally Posted by Lady72nRob71
Pickle fork thingie BAD! Hammer GOOD!
Ah come on.... It's fun just to say, I use a pickle fork and watch non-mechanics reaction.
Old April 5th, 2012 | 05:49 PM
  #122
oldsguybry's Avatar
NOVICE car nut
Yea , if you have room and it actually works , for me I had to use the pickle fork
Old April 5th, 2012 | 06:34 PM
  #123
Lady72nRob71's Avatar
Originally Posted by Troys Toy 70
Ah come on.... It's fun just to say. I use a pickle fork and watch non-mechanics reaction.
Fun to say, fun to DO!!
True, you have to have room to swing. I had lots of space with the fender wells out...
Now when i did my Ford 9 years ago, I mushroomed the heck out of that pickle fork with no budging of the ball joint. A firm WHACK at the spindle popped it loose. I kept hoping Oreilly would not charge me for damage to their tool...
Old April 6th, 2012 | 10:59 AM
  #124
oldsguybry's Avatar
NOVICE car nut
The one I rented was beat to crap . It worked well for me , but I had been pounding on it prior to renting the tool so maybe I loosened it up . The pickle fork will destroy the rubber boot though and I don't know a source where you can just get the boot .
Old April 6th, 2012 | 11:45 AM
  #125
Indy_68_S's Avatar
When I did mine I destroyed a Harbor Freight chinesium fork....and only got 1 of the 4 BJs loose. The "2 hammer - whack the spindle method" worked MUCH better for me...but I didn't have any fenders/wheelwells to deal with...
Old June 28th, 2012 | 12:26 PM
  #126
Tony72Cutlass'S''s Avatar
Well summer has come in WAY too early.
I kinda regret starting this project, but did not anticipate July temperatures in early June! Oh, well – gotta go through with it…
Back on Tuesday, I pulled the coil springs and got all the suspension parts off the car. Left side was done first.
I opted to ditch the coil spring compressor in lieu of a floor jack, blocks of wood, prybars, and a long steel rod run through the upper shock hole down to the bottom shock hole in the control arm. This rod was my protection against accidental spring launches.
Basically I got the lower control arm pivoted all the way down to the ground...
...then with the iron rod still in place, I pried the spring out of the pocket, as it had very little compression left in it. It popped a little, but the steel rod held it in. Once I slowly pulled the rod, the spring popped out (but not violently).
Rob!!
How the heck did you get the spring out of the lower pocket!! I did exactly what you've done so far, i have the spring chained to the frame so it doesnt pop out voilently. But it's sure holding in there pretty good!
The lower part of the A-Arm is completely on the ground and can't pivot any more...
Old June 28th, 2012 | 01:19 PM
  #127
Tony, lower the control arm right down to the floor. Sit in front of the control arm and push it down some more with your feet (it will prolly go about another inch or 2). Grasp the lower part of the spring (don't worry it has no energy left in it by now) and give a good outward tug. If you have a LOT of rust in there you might have to give it 2 or 3 tugs. It will pop right out. Found out after I did mine that I didn't even need to chain it - the spring energy was all dissipated.
EDIT: see 3rd para of this link: https://classicoldsmobile.com/forums...tml#post322019
Old June 28th, 2012 | 01:22 PM
  #128
midrange's Avatar
Shaking out the cobwebs..
Originally Posted by Tony72Cutlass'S'
Rob!!
You will have to raise the car higher in order to get the additional drop from the A-arm. However, if the A-arm won't drop anymore because it hits the pocket that it is bolted in,(possibly HD springs) then you're gonna need a spring compressor.
Old June 28th, 2012 | 02:40 PM
  #129
I used a crowbar, after I was sure the arm was down as far as it would go.
It popped out but the rod I had goin g through the shock holes kept it in place. It this point there is not much energy left in it. After the rod was pulled, I used both arms to tug it on out.
Old June 28th, 2012 | 03:23 PM
  #130
Thanks for all the advice!
I've gotta grab some pictures when i get home...
I can actually turn the spring around in the spring pocket. But the inner side of the spring is catching on the lip...
Old June 28th, 2012 | 04:11 PM
  #131
Keep your hands gripped on it when prying it over the lip and it shouldn't bite...
We are back in the 10x* temperatures, and I am happy to be inside with AC than doing that car over again.
Still can't believe I lived to tell about it.
Old June 28th, 2012 | 04:13 PM
  #132
Hey, Speaking of which,
The top A-Arm came out with no issues! I used a pickle fork, 5-6 blows with a BFH and BOOM, the knuckle came loose!
The top bolts were a little bit more of an issue... Those had to be really coaxed out. but hey, i didnt buy a dead-blow chisel for nothing
Old June 28th, 2012 | 06:33 PM
  #133
oldsguybry's Avatar
NOVICE car nut
yep , although I had a spring compressor on it , once the a-frame went as low as it would go the spring just fell right out
Old June 28th, 2012 | 07:05 PM
  #134
Tony, you need to have the front frame at least 15" off the ground. If its lower than that you will prolly have trouble getting the spring out. It should come out easy if you can rotate it in the LCA. That also means the energy has been totally released. You don't actually need the chain on it anymore, nor the rod. Lift the car another inch or two and the LCA will drop enough to make the extraction easy.
Midrange: Tony will likely have stock springs in his car - not the HD ones. If they were HD, they would likely have slipped out by now since HD are shorter to start with.
Old June 28th, 2012 | 07:08 PM
  #135
I've got the car pretty high up right now!! I'm actually on the train on the way home right now. Hopefully i'll have an update for you guys soon!
Any other advice with the removal of the lower control arm bolts?? I manged to get the nuts off without any issues! just... how do i get the bolts out...
Old June 28th, 2012 | 07:20 PM
  #136
Bolts will come out if you hit them with a hammer. Chances are that the bolt and metal sleeve on the control arm bushing are rusted/seized. Use a BFH and whack that sucker. Use a large punch to drift the bolt back through as far as you can. Try shooting some wd40 into the LCA bracket to see if it won't free up a little bit of movement.
re: springs/control arms. If the LCA is already touching the ground see if you can wedge some plastic (good stiff stuff) under the spring. Shoot the surface with wd40 for extra slip and give that spring a tug.
Old July 26th, 2012 | 04:44 AM
  #137
JCMC64's Avatar
JC
I had both rotors in position and parts ready so I could do them both in sequence. After both bearings were dropped into place, I peeled off the gloves and tossed them. I tapped in the grease seals with a hammer.
Rob,
What is the correct part number for these grease seals? There seems to be 2 types on Rockauto, minor difference in width, and construction. Would these work -TIMKEN Part # 8705S ?
Thx.
Old July 26th, 2012 | 07:36 AM
  #138
Originally Posted by JCMC64
Rob,
Thx.
TIMKEN Part # 8705S is the one I used and it fit perfectly. They did not have a front flange like the originals, but they worked.
Make sure you are looking at only the front wheel seals, as RA also lists the rear axle seals in that section.
The fronts vary some in width, but that is okay. Outer and inner diameter are the important things.
Old July 26th, 2012 | 03:12 PM
  #139
JCMC64's Avatar
JC
Got it...Thx Rob.
Use your threads often for shortcuts, and how to's. Awesome info. Thx for taking the time crossing all those t's and dotting all those i's!
Old July 26th, 2012 | 04:21 PM
  #140
Got it...Thx Rob.
Not a problem - glad to help out where I can!
Old October 5th, 2012 | 09:04 PM
  #141
Fummins's Avatar
Nice writeup Rob. Looks like it took as long to take and post the pics, then type the text for this tutorial, lol. And you did it with humor in a cramped work area as well.... I wear sandals as well when doing the heavy stuff, just pulled motor/trans, LCA and UCA on my 69 and still have all my toes. California heat causes it lol. Just wanted to acknowledge work well done.
Old October 6th, 2012 | 08:23 AM
  #142
Thank you for the complements!
Yes, the writeup was pretty time consuming. However, lots of detail would certainly help out those who are doing the same project, and it has.
I do take similar pictures to all of my projects, as they really help when you forget where or how a particular piece went.
The tight quarters and heat were the worst parts. I assume you saw the entire underhood resto that stemmed after the suspension was pulled. Not sure how I lived to tell about it, but I did...
Old October 6th, 2012 | 08:46 AM
  #143
oldsguybry's Avatar
NOVICE car nut
I wish I would of taken the detailed pics you did for the very same reasons .... and I feel sorry for you guys in TX . Working in that heat would kill me !
Old October 6th, 2012 | 10:52 AM
  #144
And I just keep asking myself, WHY, OH, WHY did we have to have the hottest friggen summer on record when I was doing the biggest automotive project in my life????
Geez.... This summer was hot, but "normal".
Old October 6th, 2012 | 10:58 AM
  #145
ah64pilot's Avatar
I don't see how you did it last summer Rob, it was brutal. I put my car together after paint and did the motor install but I had to work at night last summer...I couldn't have done it during the day. This summer was a breeze in comparison.
Old October 6th, 2012 | 06:01 PM
  #146
Fummins's Avatar
I havent seen that writeup as of yet, dont know if i dare look. I get inspired easy.... I might have to buy a new pair of wrenching sandals as well. Wonder if Rockauto has them in stock lol.
Old October 6th, 2012 | 07:54 PM
  #147
Surprised you missed that monster thread! Here is is for your enjoyment.
https://classicoldsmobile.com/forums...tml#post292889
Have a few beers before-hand so it does not make you start tearing your car apart.
I usually wear no shoes in the summer, but sandals work if they are needed.
Old October 6th, 2012 | 09:20 PM
  #148
Fummins's Avatar
Okay maybe I did glance at that thread lol. Beer actually encourages me, silly i know. My sun baked asphalt will take the hide off my bare feet here.
Old May 10th, 2014 | 08:15 PM
  #149
KDV's Avatar
KDV
Thanks for such a great thread Rob!
Saved me a lot of frustration
Old May 10th, 2014 | 09:47 PM
  #150
Glad it could help ya - that makes all the documentation worth it!
Old January 6th, 2015 | 06:30 PM
  #151
Just looked thru this thread. I already studied your under hood thread but had missed this one. Another great job, Rob. I am currently in the middle of rebuilding the front and rear suspensions of my 70 Vista beater. Its under Vista Cruisers and Wagons. Thanks for the pictures and instructions- I know many times that stuff does take longer than actually doing the work.
Old January 7th, 2015 | 07:12 PM
  #152
Thanks Greg, glad it helped you out, and that is the intent. I will look to your threads in the future, should I ever decide to take on a wagon rebuild. Odds of that happening are getting pretty low now, though...
Old May 31st, 2016 | 10:41 AM
  #153
oldsguybry's Avatar
NOVICE car nut
I tried to get my alignment straight on my 93 Buick without complete success . I notice the outside of the tires I bought a year ago have about 1/16 more wear then the other side of the tire does . I'm not even sure you can get it any better being I had to replace a small section of floor where the body bushings hook up in the front on the passenger side . The rear portion of the frame is getting pretty rotten where it linked to the side of the rocker panel .
Old May 31st, 2016 | 11:20 AM
  #154
If the front is toed in too much or your camber is way positive you'll get that type of wear pattern.
oldcutlass
27
January 2nd, 2013 03:17 PM
Lady72nRob71
25
April 3rd, 2012 06:26 PM
leroycjr
20
March 18th, 2012 11:23 AM
aholiday
January 12th, 2010 06:58 AM
LadySkye1080
May 16th, 2007 10:23 PM
