how to lower my cutlass -69
i figured out how to lower the car in the front but in the back its not that easy...
is there a easy way to move upp the "mounts" to the backsuspension to get the car lower? and if there is were can i buy it ? (dont want to make the lowering "fixed" if i change my mind i want to be able to set it back to standard again)
any ideas ?!
any ideas ?!
If you want to temporarily lower it to see what it looks like, just load the trunk with some heavy stuff. Won't work for checking ride quality though as the springs will be compressed. You may also get a little lowering in the front too. To prevent this place a jackstand under each frame rail as close to the front wheels as possible, then add the weight to the trunk. Otherwise, you are looking at some kind of permanent change.
How low do you want it?
I have a nice pair of GM springs
14'' tall and 7.25'' wide that you can have for shipping.
Measure your stockers at the local parts store and see how much difference they will make. I was going to lower mine (significantly) with these, but I liked the jacked up in the back with smaller wheels on the front look better.
