Help with creaking passenger side door
Old March 22nd, 2008 | 08:04 PM
Ndn_GivR's Avatar
Getting kinda bad, is it just the door pins? Leaks when i pressure wash it as well. Its an 87 Cutlass Supreme, how do i quiet the noisey wipers? Bought new blades and those springs, did`nt help. any suggestions?
Old March 23rd, 2008 | 07:14 AM
You can get new pins for your doors. I think most local auto parts stores carry kits to put new pins and bushings in the door hinges. It isn't very hard to change. All you need is a buddy around to help you hold the door.
As far as wipers are concerned, if your wipers squeak I suggest buying a new pair of blades. If it isn't the blades that are squeaking then you can always lube the mechanism with some grease.
Old March 23rd, 2008 | 08:28 AM
Ndn_GivR's Avatar
Wipers make an annoying "clattering" noise, put new 25.00 delco blades on and it did`nt cure the problem , do i need new wiper arms? Its like they`re bouncing along the windshield.
Old March 23rd, 2008 | 01:41 PM
Oldsguy's Avatar
Past Administrator
Try cleaning the windshield really well on a nice dry day with window cleaner then polish it with a product like rain-x, that shoulf fix you up.
Old March 24th, 2008 | 09:19 AM
Lady72nRob71's Avatar
If the wipers are vibrating/jumping on the windshield and new blades and cleaning the glass does not help, check the following:
1-Enough tension from the spring to hold them down on the glass.
2-Make sure the arm is not bent, causing the blade to be angled from top or bottom.
If these are okay, the pivot point on the arm is worn, causing the new blade to fit too loosely, enabling it to jump and chatter on the glass. My 97 Caddy had this problem and the dealer could not (or wanted to) figure it out. Too bad I figured it out AFTER the warranty expired...
Keep in mind junkyard arms ~may~ be worn also...
cessna195
October 29th, 2010 08:13 AM
motorholmes
June 10th, 2010 06:01 AM
69'442
March 10th, 2009 04:37 AM
J-(Chicago)
October 26th, 2007 08:12 PM
Quick Reply: Help with creaking passenger side door
