Are heavy coil springs necessary?
Old Oct 31, 2014 | 01:46 PM
camdon454's Avatar
I'm planning on putting a 455 into my 70 Cutlass, currently a small block car. I plan on aluminum heads and intake, and was curious if I would still require the heavier duty big block springs in the front. Not sure what the weight difference is between stock and aftermarket. Might be a dumb question, just trying to save a few bucks! Thanks
Old Oct 31, 2014 | 03:40 PM
With the aluminum heads and manifold you shoud be fine, I think it's an 80# difference between a SBO and a BBO. Try it and see, you can always do it down the road some.
Old Oct 31, 2014 | 04:06 PM
47 Convertible's Avatar
x2 Eric's recommendation. Might not be any weight difference by the time you have aluminum heads and manifold.
Jerry
Old Nov 1, 2014 | 02:44 PM
The difference between a stock 350 and a stock 455 is about 50 lbs. I've done this swap several times and never changed the springs - in fact, I've had to cut the springs to get the nose down to where I wanted it.
Old Nov 3, 2014 | 10:37 AM
camdon454's Avatar
Thanks guys! Very helpfull and exactly what i wanted to hear!
GSX012
Jun 16, 2015 03:33 PM
LoganMiller68
Body work
May 20, 2012 11:27 AM
Allan R
Feb 20, 2012 08:31 PM
64 Cutlass
Suspension & Handling
Sep 15, 2009 10:46 AM
geckonz08
Sep 4, 2008 04:10 PM
