Frame Identification
Gents, I have a 1958 Apache sitting on what I have been told was a 1980 Delta 88, but I have come to find the motor was a 73-74 SBO 350. It has now come time to order parts and such and I need to know what I am working with.
I found on the frame 2 304 on the drivers side frame rail and 2 312 on the passengers. Anybody with any ideas?
Also on the rear diff/axle I found ACO 311
Thanks for any help.
The second character of the VIN derivative will be the year. 8=1968, 0=1970, 3=1973, etc.
Thanks for the replys. My frame looks nothing like that posted by J-Chi, and I already decoded the engine. Now it is time to order parts for the chassis.
Does anybody know of a link or book that describes the years that big changes were made and in which models they were made. Maybe that way I can pick away until I have some idea.
The numbers I found on the frame were on the outside of the frame to the rear of the centerline of the frame. It has coil springs all around and a sway bar in the rear running right behind the rear diff. Discs front and drums rear, a rear fill for the gas tank, and the 350 has a th350 mated up.
Once again thanks for any help, glad to see I had some responses already.
Alright, I went and took another look now. Its a little harder to spot. I found 2 313 from J-Chi's spot.
So I have 2 304 on the drivers side frame rail, 2 313 on the rear vertical frame tray, and a 2 312 on the passengers frame rail.
Now what does this mean?
Alright... first, thanks for the help.
I finally read up enough to measure the wheel base, I crossed that with the capacity of the fuel tank with the info off of the olds encyclopedia. With it having a 73' 350 SBO and the numbers gathered I concluded it was a 73' Cutlass Coup. I've ordered all the suspension, steering, and brake components to completely rebuild the front and rear. We'll see if they all fit.
oldsmobilty
Sep 27, 2012 04:26 PM
1969goatman
Aug 30, 2010 07:44 PM
