Frame crack repairable???
Old Jan 16, 2008 | 05:52 AM
Pitbull2o08's Avatar
HI, my cuttlass has a slight split down the seem of the frame in the engine bay...it's about 4in. in length. my dad says he can weld that up but i was just wondering what everyone here thought. thanks
Old Jan 16, 2008 | 05:59 AM
ozoneblue's Avatar
If possible drill a hole at each end of crack then weld away
Old Jan 16, 2008 | 07:39 AM
thanks....but it'll be just as strong? or should i take extra precaution?
Old Jan 16, 2008 | 08:15 AM
Barneyo's Avatar
Let me add to what ozoneblue said - Even if you have to go out and
buy a rightangle drill -DO- drill a hole at the ends of the crack; then
weld away. You hafta make sure the stress is relieved at both ends
before welding.
Old Jan 16, 2008 | 01:44 PM
thanks... i appreciate it
Old Jan 16, 2008 | 02:33 PM
First, these frames are mild steel and a properly done weld will be at least as strong as the parent metal. The crack-stopper drilled holes are a must if the crack is closed ended. If it goes all the way to an edge, you need to take some additional precautions. One consideration is the undercut you would get at the edge of a frame flange. GM recommends using a run-off tab against the edge of the flange and continuing the weld onto the tab. This gets the start-up or tail-off undercut off the frame and the tab can be ground off later.
Old Jan 16, 2008 | 05:43 PM
Wow, you lean something new everyday. I never even thoght that a frame would crack or distort. Well, except for a reason like a collision or motor over torquing the car.
Old Jan 16, 2008 | 07:19 PM
yeah...it's like a split down the middle.
rjohnson442
May 5, 2015 07:02 AM
Joffroi
59
Apr 12, 2014 03:40 AM
yeahbuddy
Brakes/Hydraulic Systems
20
Feb 24, 2014 08:26 AM
scrappie
Mar 23, 2013 04:54 PM
Hawk1061
Body work
Jul 17, 2012 12:19 PM
