Door Hinge Pin with detent roller
Old Jul 21, 2011 | 09:13 PM
atkinsom's Avatar
Need to replace the hinge pin on the drivers side door with the roller that the little arm glides across when you open and close the door. The roller is almost coming completely off. I'm buying a door hinge repair kit that include the pin with the roller.
How do I remove the spring on the hinge so that we can get the pin with the roller out?
Does the whole pin come out with the roller included from the hinge and then you slide the new pin with roller back through the empty slots?
Thanx everyone
Old Jul 22, 2011 | 08:37 AM
With a door hinge spring compressor, available at any auto parts store:
Old Jul 22, 2011 | 09:59 AM
atkinsom's Avatar
Thank You Joe.
Old Nov 7, 2012 | 11:02 AM
jamac's Avatar
And old thread but---how did you remove the old hinge?
I have a '67 with the same problem but I am struggling with how to remove the hinge, etc.
Tight spot and some kind of strange wrench needed?
From there I guess you drill out the old pin. OPGI has a replacement pin (stub) with roller.
Part #CHV0469
Old Nov 7, 2012 | 11:05 AM
jamac's Avatar
Here is the OPGI repair kit URL:
http://www.opgi.com/p/body-moldings-...5/CHV0469.html
Old Nov 7, 2012 | 11:27 AM
oldsguybry's Avatar
NOVICE car nut
Good to know ... I have the same problem with the drivers door on my car .
Old Nov 7, 2012 | 12:38 PM
jfb's Avatar
jfb
check into a oem hinge the aftermarkets have there problems. once they are bad most usually need replacement.
Old Nov 8, 2012 | 10:02 AM
ROCKET VAPOR's Avatar
Lance
Willie will restore your originals or sale you the replacement parts.
http://www.hoodhingerepair.com/
Old Nov 8, 2012 | 12:21 PM
Lady72nRob71's Avatar
You can also repair your own hinges at home to be as good as new.
Here's my tale...
https://classicoldsmobile.com/forums...storation.html
Old Nov 9, 2012 | 08:45 AM
jamac's Avatar
All good info.
The question I have is how do I remove that lower hinge?
Is there a special wrench?
Special mehodology?
Once I get it off, looks like repair is not so difficult.
Old Nov 9, 2012 | 09:53 AM
There is a special wrench for removing the hinges, but I was able to get mine on an off with standard wrenches, a ratcheting box wrench, and an offset box wrench.
Earlier and later in my interior makeover thread, I described how I did it.
1970-W30
Body work
Dec 11, 2012 03:49 PM
69postman
Body work
Jan 29, 2012 05:07 PM
arodenhiser
May 19, 2010 01:03 PM
Redog
Aug 14, 2008 06:56 PM
69 Cutty
Aug 24, 2006 08:16 PM
