on disc brakes..
Old May 18, 2016 | 04:36 AM
sortasane's Avatar
on disc brakes..
What do you call the shaft or assembly that the front wheel bearings and rotor mount to on a disc brake system?
Old May 18, 2016 | 04:39 AM
m371961's Avatar
Spindle
Old May 18, 2016 | 04:42 AM
sortasane's Avatar
That is what I thought, but every time I try to find one the wrong parts come up.
Old May 18, 2016 | 06:41 AM
On most Oldsmobiles that shaft is actually an integral part of the steering knuckle. Many people will use the term "spindle" to mean the whole knuckle, not just the shaft itself. Since it is not a separate part, that's probably not an issue. If your bearing surfaces are damaged due to a seized wheel bearing, you need to replace the entire knuckle. Tell us year and model and drum or disk brakes.
72allblackcoupe
Apr 6, 2014 07:20 PM
1carsick
Brakes/Hydraulic Systems
23
Oct 2, 2012 05:50 PM
russell-t
Apr 30, 2011 05:56 AM
<c. larson>
Cars Wanted
Sep 23, 2006 05:57 PM
Det313
Jun 22, 2006 04:16 PM
