Body mounts for 72 cutlass from Fusick
Old Nov 6, 2015 | 07:08 PM
Oldssupreme's Avatar
Chris
Hi. Does anyone have any insight to installing the body mounts on a 72 cutlass? I purchased from fusick, and there are several rubber mounts with a metal sleeve inserted. Two of these have a small opening in the sleeve and the others have a larger opening. The assembly manual gives a few different numbers for the top mounts but the kit i got doesn't seem to jive with these numbers. Also, should the #5 mounts be the rubber mounts with no metal sleeve? These are the ones that just sit on the frame.
Thanks!
Chris
Old May 13, 2017 | 03:02 PM
Zr1bandit's Avatar
Did you ever get an answer on the different size holes in the metal inserts ???
joesw31
May 31, 2015 04:17 PM
70 Racer
May 31, 2013 04:16 AM
1k442
Feb 19, 2013 01:08 PM
Nasty455
Mar 20, 2012 04:57 PM
flatoz
Mar 15, 2009 02:03 PM
