Wheel Play
Old May 17, 2017 | 09:52 AM
77ricbaez's Avatar
Wheel Play
I checked the play on my wheels and found side to side play and not up and down play.
My mechanic told me that it's the wheel bearings but I don't think so, there would be up and down play too.
Upon further inspection of the front end, I noticed that the driver side tie rod adjustment sleeve was loose, I could rotate it by hand with the wheels on the ground.
I just want to know if this would cause play in the wheels.
Old May 17, 2017 | 11:01 AM
To determine wheel bearing play, with the car up on jack stands grip the tire at the 11:00 and 5:00 positions and rock it in and out. The tie rod ends will rotate on the pivots.
Old May 17, 2017 | 11:37 AM
RandyS's Avatar
The sleeve being loose on it's own would not create 'play', but could contribute to alignment problems. Worn tie rod ends could allow 'play'. But you are likely correct, a bad or loose wheel bearing would have play side to side and up/down.
Old May 17, 2017 | 02:03 PM
Agreed. The side to side play could be tie rod ends or other steering components.
Jimoldsfan
Sep 25, 2013 01:38 PM
AboutClassics
Jul 31, 2011 01:14 PM
rtpassini
Dec 24, 2009 07:51 AM
Jamesbo
Oct 13, 2009 05:22 AM
Jamesbo
Feb 10, 2009 04:21 PM
