Body Mount Bushings
Body Mount Bushings
I need some help from the C.O. experts on finding a correct set of body mount bushings for my 1969 Olds 442. I have searched different sources and none seem to have the correct number of bushings without the bolt holes. I have six that don't have bolts through them. I prefer to use new nuts, bolts and washers if possible. Thanking you all in advance.
This may be the closest you'll find? I had same issue with a 1970. The kit I bought had only two solid mounts when I needed six. It doesn't seem like a big deal to add some bolts? but I understand. You may just have to buy a couple extra solid mounts to add to this kit.Thats what I did.
https://www.ebay.com/itm/Oldsmobile-...97.m4902.l9144
