75 delta 88 Rear end sits uneven
Old Aug 22, 2013 | 10:50 AM
arod40's Avatar
Driver side Rear end sits uneven have replaced springs, shocks .. It's annoying to look at its about a 3/4in difference on rear driver side.. Any idea on what else to look at? Thanks
Old Aug 22, 2013 | 12:13 PM
1975 Chassis Service Manual, Figure 3.69, states, "Tolerance: Side to side +1/2" to -3/4" (Max difference 3/4")."
Don't be so picky.
If it really drives you crazy, put a 1/2" to 3/4" shim under the low spring.
Old Aug 22, 2013 | 12:28 PM
It could be a front spring causing this also.
Old Aug 22, 2013 | 02:29 PM
jaunty75's Avatar
I was thinking that that 3/4" difference might actually be within spec.
I held my thumb and forefinger 3/4" apart and then tried to decided if I'd notice that size difference in ride height from 10 feet or 50 feet or whatever feet away. I think the answer would be that I wouldn't have noticed it unless it was pointed out to me, and then it would forever bug me.
Old Aug 27, 2022 | 06:20 AM
arcflashfisher's Avatar
My car was the same.
I know this is an old thread but I thought I would post in case someone else was curious. I have a 1975 Delta Convertible. I changed the original shocks and springs and have the same 3/4" inch difference in the rear. It did raise the rear about an inch though.
Seff
28
May 15, 2014 08:37 AM
camdon454
Suspension & Handling
May 9, 2014 08:17 PM
viper771
Feb 15, 2013 07:38 PM
88ToroSteven
Dec 25, 2011 01:37 PM
jpaulwhite
Ninety-Eight
Aug 3, 2010 08:35 PM
