75 delta 88 Rear end sits uneven
Driver side Rear end sits uneven have replaced springs, shocks .. It's annoying to look at its about a 3/4in difference on rear driver side.. Any idea on what else to look at? Thanks
1975 Chassis Service Manual, Figure 3.69, states, "Tolerance: Side to side +1/2" to -3/4" (Max difference 3/4")."
Don't be so picky.
If it really drives you crazy, put a 1/2" to 3/4" shim under the low spring.
Don't be so picky.
I held my thumb and forefinger 3/4" apart and then tried to decided if I'd notice that size difference in ride height from 10 feet or 50 feet or whatever feet away. I think the answer would be that I wouldn't have noticed it unless it was pointed out to me, and then it would forever bug me.
My car was the same.
I know this is an old thread but I thought I would post in case someone else was curious. I have a 1975 Delta Convertible. I changed the original shocks and springs and have the same 3/4" inch difference in the rear. It did raise the rear about an inch though.
88ToroSteven
Dec 25, 2011 01:37 PM
jpaulwhite
Ninety-Eight
Aug 3, 2010 08:35 PM
