72 rear springs
Old Dec 23, 2013 | 06:37 PM
rockdr's Avatar
72 rear springs
I'm installing a pair of Moog 5379 springs. The two ends are almost identical but not quite. One end is slightly "flatter" than the other. WHich end goes up? And is it true that the "points" of bottom ends of both springs should point left, toward the driver's side?
Old Dec 23, 2013 | 06:56 PM
The 'flatter' section of the spring goes on the axle saddle and the wide sections to the top. The upper pigtails both face to the left as indicated in the Assembly Manual. When installing these springs, also ensure you put new rubber isolators between the spring and upper mount ring.
bigjaythe1st
Suspension & Handling
May 8, 2012 05:45 PM
1acesmith
Aug 11, 2011 11:03 AM
cola
Jun 18, 2008 08:34 PM
72Cutlass
Apr 12, 2008 07:54 PM
