68 cutlass s frame
Old Dec 25, 2007 | 10:55 AM
olds1968's Avatar
member
68 cutlass s frame
i know my frame is bent on the front end because i cant get it aligned right. does anybody know the best way to get my frame straightened?
Old Dec 25, 2007 | 01:56 PM
kevinkpk's Avatar
Not knowing the history or where you are taking it to get aligned, I'd be leary of somebody telling me I had a bent frame, true it could be, and there are places that can "straighten" them.
You could have worn out ball joints, control arm bushings, or even shocks. If it were me, I go someplace else to have another diagnosis on it.
Old Dec 25, 2007 | 04:45 PM
68conv455's Avatar
You can also conduct some basic measurements yourself. Measure the frame at the front half of the car. Measure diagonally. For example, measure from good semetrical frame reference points. Start from somewhere on the frame roughly under the drivers foot, to a good reference point on the frame at the passenger side front. Repeat the measurement from passenger side to drivers front. Your measurements should shape an X pattern. If you use good semetrical reference points on the frame, the two measurements should be nearly equal. If they are not, you picked bad points or your frame is tweeked. I believe if you get a chassis manual for your car the accurate dimensions and measurement locations are stipulated.
Old Dec 26, 2007 | 05:29 AM
olds1968's Avatar
member
thanks for the info guys ill look into it.
Old Dec 26, 2007 | 07:49 PM
GoodOldsGuy's Avatar
442=A perfect 10
Take your car to a quality frame and alignment body shop. There are many that specialize in frame straightening. It requires specialized equipment and knowledge.
Regards,
Fred
oldsmobilty
Sep 27, 2012 04:26 PM
sixty9olds
Jun 14, 2011 06:43 PM
1969goatman
Aug 30, 2010 07:44 PM
DJMatthews
Dec 5, 2006 01:28 PM
