68 442 body lean
68 442 body lean
I have a 68 442 convertible and I did a complete frame off restoration and during reassembly the entire suspension was replaced all bushings on control arms, shocks, springs etc what I notice is a body lean and I cant figure what I did wrong. there is about 3/4 of a inch difference from the driver side and passenger side, I have been told by few people this is a common problem with these vehicles but im not sure if that is true, I was also told to install a coil over shock where it is adjustable and I can adjust the height, can someone guide me in the right direction to find the problem I know without seeing the vehicle it is hard to determine but if this is a common problem maybe someone has knowledge and may help, also if the coil over is the right option does anyone know a good brand to purchase and from what location thanks for all the help and time you have taken to help me with my project
Did you torque all suspension bolts with the weight of the vehicle on the tires on a level surface? May sound silly but make sure you are "seeing" this while parked on a level surface. Also may want to insure the springs are all in thier "pockets"-for the spring pig tails.
Also if the front wheels are turned when your measuring it will cause the issue. X2 on tightening the moving parts with the car in the air and make sure the springs are in the pockets and clocked correctly.
I recently loosened the front suspension and control arms drove the vehicle for couple miles and retightened everything on the ground now I did remove both springs and I feel they were both upside down the flat part of the coil was in the control arms but both sides eere like that, I am reinstalling the springs in the correct eay and when im done I will let you know how I made oit just for future reference and knowldge, thanks for your time and knowledge
Did you have the frame checked before reuniting it with the body? All body off frame restorations require checking the frame for x y & z axis on a frame jig. An old frame can have a twist just from many hard launches or a light hit etc...It can be done with the body on. Once you've exhausted all the above items take it to a well known, experienced, high quality frame shop for a look. Worth the setup time just to be sure. If it does in fact need to be tweaked make sure the tech knows what their doing as far as how to not let it effect the body, especially on a vert.
The likely cause of this problem was not so much the upside down springs as the fact that the one on the high side was likely not properly seated in the UPPER spring pocket in the frame. As you know by now, that's a blind installation, and it is very easy to get the spring off center so that it sits on the center locating cylinder and not around it. This will cause the height discrepancy you had. Apparently you got it installed correctly on the second try, whether you knew it or not at the time.
