66 starfire body mounts
Someone will chime in on this. FYI when you post the same thing 2X in different areas it doesn't speed up the answer process. If there's an answer it will pop up in the New Posts right away. You will also get automatic email responses when someone replies. Suggest you should delete one of these posts to streamline responses or ask one of the mods to merge it for you.
You can obtain the core support kits from Fusick Automotive Products. They show the kit to be for 66-70 88's and 98's but the parts book says Starfire is the same. Body mounts is a whole different story. After much looking, I finally settled on measuring the rubber parts and searching the Steele catalog for the nearest fit. I don't remember what car they came from but it might have been a Pontiac or Buick. The steel cones are not available unless you happen to find a salvage yard with a body still on the frame. So many are just crushed and they never think about some of these very hard-to-find pieces.
joesw31
May 31, 2015 04:17 PM
