2 inch drop Hotchkis Springs front and back
Anyone running a 2 inch suspension drop with Hooker full length headers (3 inch collector)? If so what is the clearance at the flange? I have heard 4.5 inches is the absolute lowest you want. I would be at 4 inches so I think I will have problems.
Just know the car, and be careful going over railroad tracks and speed bumps. I installed Moroso Trick Drag springs on my car and it dropped at least 2" and I have no problems even with the 90/10 drag shocks...but I don't drive it fast over something I suspect may cause it to bottom out. Of course, my oil pan is lower than my headers so I'll have bigger problems than a banged up header if I do bottom out
Thanks.
I was also thinking that the 2 inch drop will not really be 2 inches based on two facts.
1. The Hotchkis springs will lower the car 2 inches. This is assuming the car is stock. I have aluminum manifold and radiator. I also removed all the A/C components.
2. My rear wheels and tires are larger than stock. (went from 255/60/15 to 295/45/18) front is the same diameter
What size dip stick are you using for your deep pan?
The 2 inches is based on stock suspension/ride height. I have seen people replace springs on older cars and the ride height went up believe it or not? Depending on the age of your current suspension(springs, shock, bushings) your results will vary.
^^ This...I have seen more guys get 2" lowering springs and actually RAISE their ride height because their stock springs were worn out. In fact, most 2" drop springs aren't going to drop you 1" let alone 2". Your best bet is to do the springs and spindles to get the ride height you want.
I used the hotchkis tvs system and I used the 1" lowering coil springs and I'm totally happy with it. I was going to use the 2" but I am glad I used the 1" I like the way it looks and rides and you can tell its lowered just a bit.
It's a bit rough on crapy roads but on smooth roads its awesome! I swapped the steering box as well and billstein shocks all around.
If you don't plan on improving the suspension geometry, both will do the same thing. I would not combine a dropped spindled and lowering spring as you would kill most if not all your suspension travel. The if you want some of both(drop and suspension improvement), you could do the lowering springs and tall ball joints. The tall ball joints would help out with the negative camber issues inherent in all a bodies.
I just dropped mine using the 1 inch type. I am very happy the way the car sits now. After taking off so much cast iron off the front of the car it had a rake from back to front. It now sits evenly all the way around. Remember also that these springs have (I don't know the word for it) a better rate meaning they don't squish as much as stockers. It does make me nervous about the headers. I have a friend who has the same setup and as AH64Pilot pointed out you take it easy going over high or bumpy situations. Simple logic really. I have driven his car and never did the car come close to bottoming out.
Tomorrow it goes for the paint chips to be fixed. After that I should be driving it. On the 12th of never it seems! When I get it back I will post plenty of pics to show the work that was done. Radiator, electric fans, dropped, etc. See you then.
My car is lowered now, just gotta try to figure out how far it's been dropped. Springs were just fine with the small block blower motor, but I installed a BBO with cast heads.
Wouldn't the lowering springs make for shorter suspension travel?
Thanks. I'll be going with the tall spindles, for sure. Replacing just about all the suspension components including geo. corrected tubular a-arms. Want to go with disc brakes in the front anyway.
If you really want to learn more about suspensions, check this book out by Mark Savitske
http://www.amazon.com/Make-Your-Muscle-Handle-Performance/dp/1934709077">http://www.amazon.com/Make-Your-Muscle-Handle-Performance/dp/1934709077" /> http://www.amazon.com/Make-Your-Muscle-Handle-Performance/dp/1934709077">http://www.amazon.com/Make-Your-Muscle-Handle-Performance/dp/1934709077
Or give him call at SC&C. Just be prepared to learn more than you probably want to know...lol
No prob...If you decide to call Mark, at least get his book and thumb through it. It provides an excellent foundation.
He's a great guy and has worked with many suspension manufacturers in design and consulting
www.scandc.com
He sells parts, but is not loyal to any brand and will tell you why one brand could be better than another. He also will help you with what fits your budget, whatever it may be.
www.scandc.com
rough ride
I don't know if I can handle the rough ride much longer. For some reason the guy installed BMR Suspension Lowering Springs SP034R. I thought he used Hotchkis. The BMR is a progressive spring so maybe that's why the ride it ruff? It feels like the suspension has limited travel. 2 inches is not that much. I am running the KYB shocks
I am to the QA-1 Coilover or the Hotchkis. About the same price. The QA-1 is adjustable. Which is a plus.
The KYB's IMO are the problem, take a look at Ridetech, Varishocks or Viking for a better ride. I'm not a fan of coil overs on stock lower control arms, they're too weak without reinforcement to handle the load.
All things considered go with the Ridetech RQ. The shocks are made in conjunction with FOX and have a 100k mi warranty.
dc2x4drvr suggested those other brands because they are BETTER and their pricepoint is acceptable. The reason Vi-king shocks exist is because Chris and Christina King left QA1 to form a company with a partner they knew could do it better than what QA1 has done.
Maybe you should google "qa1 leaks" to see what I am talking about and to get a better picture of problems people have with that brand and the lack of customer service. This would play a big part in whatever brand I chose. I know that Ridetech has great customer service from dealing with them personally in the past.
Whatever you choose, good luck.
dz442
September 6th, 2019 03:55 PM
bigjaythe1st
Suspension & Handling
May 8th, 2012 05:45 PM
oldzy
March 2nd, 2011 08:40 AM
oldzy
January 2nd, 2011 04:20 PM
