wanted: 1968-1972 Cutlass
Mainly looking for solid body and frame. 1970 preferred but would consider the other years above also. Can be complete running car, or complete without motor as I can salvage the one I just built for mine. I'm planning to spend at least 5500 but can go quite a bit higher for the right complete running car.
Thanks for all the replies but I found number 2. Bought it in NJ and brought her home. I am the second owner of this car. I am putting in motor from my wrecked one over winter but this is a running decent car so I'm gonna run it til the snow flies......more to come on build number two. Lost and found.....
Keeping all except for dash and tilt steering column. Its a column shift but the rod in engine compartment is bent.....dash is pretty good except cut up for radio. Dash pad is gold and no cracks and ashtray door is split. Its an a c car too if that helps. There is no headliner, carpet or rear shelf. The panels I'm using in the new one.
