1953 Olds Rocket 88 So Calif car!!!
Old Jul 30, 2008 | 08:54 PM
NATESBPD's Avatar
My brother has too many car projects so im putting his car on here.. It is a 1953 Oldsmoble with a rocket 88 motor,, original trans. The engine starts and runs! Dont know much about transmissions, but the car drives, but seems like it is in a high gear! The body is straight and has original paint. All moldings are there! All glass is in and no cracks.. original door panels ect... I think this is a great steal and would take very little to make it cool! very little rust. He wants $3,000 or BEST OFFER! Just ask for more pics...
Call Ryan (909) 915-4897
Old Jul 30, 2008 | 10:36 PM
88 coupe's Avatar
Junior Member
Welcome to the site.
Originally Posted by NATESBPD
........ the car drives, but seems like it is in a high gear ........
The trans is a Dynaflow, instead of the expected Hydro.
GM Hydramatic plant burned down during the '53 model run. Until production resumed, in the new facility, Olds and Cad used Dynaflow from Buick.
Performance levels were about the same, with the Dynaflow giving up a bit to the Hydro's 3,82 first gear, then gaining it back after its 2-3 shift.
Dynaflow MPG was a bit lower because of turbine slippage vs lack of it, in fourth gear, with the Hydro.
Might be a desirable feature for a potential buyer.
Norm
Old Jul 31, 2008 | 06:10 AM
That seems like a decent deal. Especially if it still runs. Is the car still in southern CA?
Old Jul 31, 2008 | 07:10 AM
NATESBPD's Avatar
1953 olds rocket 88
still in so calif about an hour east of LA. If i knew anything about Olds id tell you what engine and trans it has.. it should be the original rocket 88. after looking around this forum.. i think i might buy it from him... body moldings are all there and no dents on body... it would take very little to make the car really nice.
Old Aug 3, 2008 | 09:20 AM
NATESBPD's Avatar
No bites, and after being on this site... i think ill keep it,, now i need to read up... The car runs, has reverse.. but when i put it in dr it seems like i have the brake on or its in a high gear.. tryed the other gears with no luck.. ill try removing the trans pan and filter.. repace the fluid.. any other sugestions?
Old Aug 3, 2008 | 08:06 PM
88 coupe's Avatar
Junior Member
........ but when i put it in dr it seems like i have the brake on or its in a high gear ........
Sounds like a Jetaway, when one is used to driving a real Hydro.
A missing, or disconnected, TV rod could cause a similar symptom. One rod goes from the carb to a "bell crank" affair and the other attaches to the longer of two "shifter" arms at the trans. It's all detailed in the factory manual.
How fast have you driven it? As much as 35 miles per hour? If so, with a "light foot" you should been aware of three distinct gear changes.
........ tried the other gears with no luck ........
Dr, S, and Lo, positions are all first gear. Until it shifts into third gear, there is no difference.
........ ill try removing the trans pan and filter ........
There is no filter, only a screen that may, or may not, need to be cleaned.
........ any other suggestions?
Have the service done by a competent trans shop. They will "read" the debris in the pan, and give you an idea what you are up against. They can also tell you, for sure, which trans you have.
If you choose to do it yourself,
Cal Tex Automatic Trans Parts
1541 W Brooks St.
Ontario, CA 91762
(909) 988-9697
should have the pan gasket, you need.
Norm
Old Aug 3, 2008 | 09:14 PM
NATESBPD's Avatar
Thanks for the great replies!,, i think you have a new olds owner.. ill keep u posted after i remove the pan and fill it back up with transmission fluid.
Old Aug 18, 2008 | 10:11 AM
TECH9TWISTA's Avatar
Talking
lmao it starts with selling the car then u buy it then ur an oldsmobile fan 4 likfe lol o well gotta start somewhere have a good day
mobileW-30
Feb 1, 2013 01:41 PM
vistacruiser1971
Jan 4, 2012 10:47 AM
leepear
Dec 1, 2011 04:00 AM
supremes
Dec 14, 2008 10:42 AM
55spyder
Aug 2, 2007 11:10 AM
