Need to sell a 71 Cutlass Convertible Any Takers?
Old Apr 26, 2009 | 12:47 PM
ThyPlumber's Avatar
Smile Need to sell a 71 Cutlass Convertible Any Takers?
If anyone is internested in buying a 71 convertible let me know car needs to go.....Car is not far from being finished below is work done/needs done
71 Oldsmobile Cutlass Convertible For Sale
Unfinished Project Car
Call: 708-447-9640
You can call anytime, car is sitting at Plumbing shop, ask for TJ or John
Will E-mail pics if you are unable to stop out and see the car
Mechanical Work That Has Been Done:
Motor Rebuilt- 350c.i. Has Flat Top Forged Pistons, Dual Pattern Cam Performer RPM, #5Heads, New Alternator, New Quadrajet correct for 71, New Intake Performer RPM, Original Distributor Replaced Points with Petronics, Bearings, Gaskets ect.
Trans Has 2200 Stall Converter/Shift Kit.
New Dual Exhaust, Factory Style.
New 4 Core Radiator / Fan.
New Disc Brakes Front/Spindles/Bearings.
New Power Booster/Master Cylinder
New Brake Lines/Front Rear
New Suspension, Springs Front/Back
Replaced all bushings joints
New Steering Column Tilt Correct for 71
New inner-outer tie rod ends.
Body
Frame Stripped painted.
Body Stripped.
NOS Passenger Fender.
Fenders, Hood, Doors reworked-primer urethane.
Bumpers Re-Chromed.
Wire Harness good/tested.
Convertible Top/Black has Glass Rear Window.
Has (5)Rally Rims (Factory)- BFG's Good, Beauty Rings Good\Original, Center Caps Good (Full Size Matching Spare).
Interior
Color Pearl White
Strato buckets Correct for 71.
Driver Seat Recovered/new trim/back cover.
Rear bench Recovered.
Council / wood **** shifter.
New Carpet.
New Interior Arm rests/ door panels.
Have Most all New Interior Parts.
Wire Harness Tested Good.
Has All Glass Installed (good)
Work Needed to finish Body:
Both Rear Quarter Panels Need patch panels around wheel opening. Needs Complete Paint Job.
Bright Work(Trim Needs Polishing) reinstall (Have Trim).
Need Complete Weather-Strip Kit. Passenger Seat needs to be recovered. Have all covers Parts New.,
Interior Needs to be re-assembled (door panels ect.) after Paint Job.
Parts with Prices Needed To Complete Car:
The Parts Place, In Elburn, IL Used to determine parts prices
New Convertible Top motor/lift cylinders $460.
Complete Paint Job. price ???
Needs New Door Handles-Locks-Trunk Lock $90
Needs Windshield Wiper Arms $89
Needs new Emblems Kit $119
Needs Full Weather Strip Kit $439
Interior Window Crank Handles $24
Needs Driver And Passenger Headlamp Bezels $100
Seat Belts Front/Rear Originals Old/Worn $125
Needs New Steering Wheel (Steering Wheel Wrong Color) new 4 spoke kit $329 Needs Interior Sun-Visors $89
Needs Radio ???
Needs Under Hood Insulation $24
Needs spare tire jack kit $100
Needs L/R Quarter Panels, L/R Outer wheel housing $1210
Trunk Floor Mat $100
Will Need a few odds and ends parts Clips/Nuts Bolts-not listed here.???
Total Parts Price $3298
auto_editor
Aug 13, 2018 06:14 PM
pmathews
Dec 6, 2013 07:23 PM
Hairy Olds
Dec 4, 2013 04:07 PM
cfair
Jun 11, 2009 10:25 AM
marinus_
Mar 18, 2009 05:09 PM
