Some people just should not be allowed to own paint guns
My question is, does it really have over 350,000 miles on it, and does he really know that the mileage is exactly 352,082? The odometer would have had to have turned over three times now, and with only five digits, does he really know how many times it has turned over?
Of course, when a car reaches that many miles, who cares how many miles are on it. He could have just said "off the dial" and be done with it.
It does kind of look like a police car in the background of the first pic so they may have gotten it from a drug auction.
I also see you have a Monte Carlo, is it an original BB car? My dad and I have a few, 3 of them are BB cars, 2 of those are documented SS454 cars and the third is a 72 factory 402 car. Good to see another Monte around.
She's a Delta CUSTOM evidently- taillight halves in the bumper. Paint is an easy fix. Red interior, have to live with it I guess.
Seller sounds kind of impaired. "[then] realized how much work it needed..." then the flaws listed are: "No windshield wipers, no trunk locks, no antenna" - that's it? Oh, damn SO MUCH work it needs.
I cannot decipher what the engine info is about- looks like he read the machinist's bob weight calculations and typed them into the ad like those numbers are exotic cam specs or something.
"I have had this car a month. Purchased for my 15 year old, realized how much work it needed, ready to sell. I have the information it was listed with when I purchased it. I do not know how much is truth, I took the seller at his word.
NEW MOTOR V8 433 bored over with higher compression ratios 10:1 40 miles
Rods sml end 271.0 big end 630.0 valve jobs Piston 657.8 bearing 62.3 guides installed
Pin 187.4 total 685.3 exh. seat Locks press rods/throw 2 mill heads
Rings 58.2 total 1370.6 rod resize TOTAL 1174.4 OIL 4.0 crank grind MO30/RO20
Pist/ throw 2 rotating wt 1374.6 recip weight2348.8 factor 1174.4 each half 1274.5
times 50 bob weight 2549.0
NEW PARTS edel brock thunder series 650 carburetor, 2 tie end trw, ball joint trw-front-&rare, 4 coil spring(moog), centerlink front en1, 1ps & core ps gearbox crdne, 1 core ps pump crdne, a1 distributer, 8 high performance flat pistons ($800)
Dayton 24 Inch Wire Spoke Rims
Extra steering wheel, wood, nice
All glass is intact"
Careful, Jaunty. Remember, when paint gun are outlawed, only outlaws will own paint guns...
And you can only begin to guess at the horrors that you would see if that ever happened!
Chris, you have a talent for understatement -
I would say that that listing looks like it was written by someone with brain damage, but it would be insulting to people with brain damage.
1. Will you do something stupid with the paint gun? ___ yes ___ no
"If your answer to #1 is "no," please proceed to the cashier. If your answer is "yes," the exit is to your right."
I wore out with their vast knowledge of the 433 engine specs!
If the paint is shiny and the body work was in good shape its better to look at that than a run of the mill grandpa nerd car.
OK, give us an example of a "run of the mill grandpa nerd car," and, before you answer, remember that there are many people on here who own what you might consider a "grandpa nerd car," are very proud of them, and would be more than happy to hand you your head on a platter if you say something stupid.
