1970 442, with the original 455 motor rebuilt, The original OG trans has been rebuilt, the original 3.23 posi rear has all new seals and bearing, the car is all original except for a few changes , we put an edelbrock carb on it and we added power disc brakes, the frame was sandblasted and painted semi gloss black, all new brake and fuel lines, new shocks and springs, the interior is all new with distinctive upholstery, new firewall pad and under dash insulation, the car is a correct code 28 twilight blue car, with black interior, original non ram air hood car, with a hood lock, also I believe it was a stripe delete car, as we were sanding it down we could not find any evidence of a stripe, new gas tank, all the stainless has been polished, we also have the protecto plate, and the statement of vehicle sale from the original dealer, Story Oldsmobile, also other paperwork ,like warranty card, Oldsmobile accessories booklet, and consumer information booklet. asking $62,000 OBO message me for any information or questions, car is located in Ohio
The block had to be bored 30 over, had new pistons, rings, crank is standard, with new bearings, new oil pump and screen, cam is a roller with stock lift and duration, have cam card, heads have all new valves with 3 angle , springs are set up for roller cam, do have all receipts for the machine work.
What octane gas are you using? I have only 91 with 10 percent ethanol here where I live. I know that year 455 likes Super Premium gas, but all we have here is regular premium. Also, how much body filler is under the paint? And, how long have you owned the car? Your rebuild looks really good. I'm debating within myself whether I can live without A/C or not. Super hot here in the summer. Thanks.
The best way to have A/C on these old cars is to add it later via Vintage or another source. The factory A/C car HVAC controls are vacuum operated which is problematic in 50 plus year old iron. Cleaner install too.
I use 87 octane in it with a bottle of additive in every other tank full, that seems to work great, with no pinging at all, we used a little over a half gallon of filler on the whole car, We have owned the car for about 9 years. the A/C is best to use the vintage air after market units, they work better anyway in my opinion.
John
I will put one on it if you are interested for $52K, what color would you like. I also been thinking about putting a ram air hood on it, what do you guys think about that.
John
Well, I did it, I put a ram air hood on it, said I wasn't going to do it but here we are, now the car has a functional original ram air hood , the car is stripe delete. so no stripes anywhere.
price is 58K , Here are some pics
Do you have a better picture of the back? The pictures on MarketPlace make the trim at the back of the quarter appear to be sitting an inch higher than the trunk molding
The number matching engine, was taken to a machine shop and had the cylinders bored 30 over, new cam bearings and brass freeze plugs installed, new pistons installed on rods, the motor was checked for cracks, the original E heads were reworked with all new valves and springs and a 3 angle valve job, then was assembled with new piston rings, rod and main bearings , new roller cam set up, new oil pump and screen, and here is a pic of the rear of the car
yep I was going to offer also . I know its a stripe delete car and I understand trying to keep true to the originality when restoring it but man thats a lot of blue with no stripes to break it up. beautiful car , if it had stripes and a lower price it might be in my garage . Im going to watch the auction also, who knows he might get more than he's asking here.
