Care and Appearance Washing, waxing, paint care products, etc.
Convertible Top/Glass Seperation
Old November 5th, 2013, 12:26 PM
Propaneking's Avatar
I've got a slight seperation starting with the back glass and the convertible top. Glass has pulled away from the bottom corners outside edges on the outside of the top. Any technique anyone has found to re glue the top to the window? I'm thinking an epoxy, don't think silicone would be strong enough.
Propaneking is offline
Old March 16th, 2014, 06:33 PM
w30442's Avatar
top
I hate to say it but I have been down that road and did not find anything that worked, the only cure is a new top, bummer news. Good luck I hope you find something
w30442 is offline
Old March 16th, 2014, 06:45 PM
71 cutlass convertible
lshlsh2's Avatar
Haven't found anything either
Larry
lshlsh2 is online now
Old March 16th, 2014, 06:55 PM
Octania's Avatar
Krazy glue and start saving for a new top.
Octania is offline
Old March 16th, 2014, 06:57 PM
mrolds69's Avatar
You can't fix it, but if the rest of the top is really good, you can change just the rear window. The prob is it's a ton of labor and better to do the top + window at the same time.
mrolds69 is offline
Old March 16th, 2014, 07:23 PM
Proud Viet Nam Veteran
redoldsman's Avatar
I would try contact cement and like these guys said, start saving for a new top.
redoldsman is offline
Old March 27th, 2014, 09:45 AM
68442Convertible's Avatar
It is possible to reglue a glass window in a convertible top. I have done it. Mine does not leak.
The preferred glue is 3M Windo-Weld #08609. Also use 3M Single Step Primer #08682 on the glass. I got both at Napa.
You will need to prop up/support the window - I cut some 2x4s and put padding on the ends - and tape the window to the top after you apply the glue - I used blue masking tape.
The Windo-Weld can make a mess, so I masked off the glass and top. It is black and sticky.
There are instructions online in various places. Here is an example. Good luck.
http://www.j-body.org/forums/read.ph...53388&t=153388
68442Convertible is offline
Old May 9th, 2014, 11:32 AM
Update - After 2 years, I have a slight separation between the Windo-Weld and the glass in one lower corner on the outside. I am attempting to rebond the glass to the Widow-Weld with superglue.
The Windo-Weld cures to a flexible plastic/rubber - almost like a molded part. IMOP it does not stick to glass very well - not to hard to pull it off.
The inside separated in both lower corners. I reglued it with E6000 - an automotive/industrial version of Goop. This stuff is way stickier than Windo-Weld and seems to work better on the inside.
Old June 30th, 2015, 07:09 PM
Ryan McManus's Avatar
I have used windo weld by 3m and seems to work great
Ryan McManus is offline
75hurstoldsW-30
September 12th, 2014 06:23 PM
75hurstoldsW-30
September 8th, 2014 03:18 PM
CajunCutlass
January 27th, 2014 09:49 AM
allyolds68
February 22nd, 2011 03:18 AM
Nickthefish
October 16th, 2009 06:15 AM
Quick Reply: Convertible Top/Glass Seperation
